Wow amazing. Just through sheer set up, no additional cost of components. I forget... Is your SAT Opus on the same table?
SAT Opus is on Kronos.
Congratulation Tang,
i am really happy for you,you have the top of analog
Today Dietrich the Axiom tonearm guy came to redo my setup of Axiom/Palladian. He did his things while I was having meeting most of the day. An hour ago I entered the room to listen. The sound is now excellent. This combo is now playing on the same level as my SAT combos, but with different tone. More body than Opus and Coralstone on SAT. High extension is not as good but more majestic in bottom end. Energy, pace, resolution and innerdetail are all here now. He changed armboard to a new one and gave me titanium headshell screws. When I left the room, He was measuring distances and dimension of my EMT and said he could customize the Axiom to fit my 927 from the rear.
Tang
I am curious if anyone has directly compared the Acoustic Signature TA-9000 with any of the top arms being discussed.
TA-9000 maybe even rarer than other arms mentioned here. I only see owners of Acoustical Signature turntable use TA-9000. Two Invectus in Thailand came equipped with these arms. The owners of these Invectus also dont have arms that are mentioned here. There is not much info about it available. How do you like it on your Ascona?
Kind regards,
Tang
This is what guyser had with the etsuro urushi in the horn mentioned in my DIY horns report
No idea. Will have to compare it to his fr64s at some point
Hi Ked.Hi all,
Feel free to rate the tonearms in the following buckets based on your experiments. Will give something to muse over
1. Sonics for playing classical LPs while playing with neutral, dynamic carts, like Ortofon A90
2. Ease of mounting
3. Ease of adjustment (VTA, SRA, swapping carts, etc).
The tonearms are: Durand Talea II, Da Vinci Grandezza, Thales, Schroeder LT, FR66s, Ikeda 407, Air Tangent 10b, Kuzma Airline, Kuzma 4P, SME 3012.
Additional comments welcome. While ranking you can also add in parentheses next to the arm the carts you have experienced them on
Did you try the Groovemaster with Koetsu? If so, which Koetsu and how well did the combination work?I just ordered one of those GrooveMaster II arms in Titanium. Interested in how it will mate with Koetsu.
I had a bad hum and had to sell the arm. For $2500 I can't imagine a better tonearm than the FR-64S for a Koetsu.Did you try the Groovemaster with Koetsu? If so, which Koetsu and how well did the combination work?
