Thanks to each of you for contributing to this thread!
I, for one, have learned from this thread a lot about a lot of amplifiers -- without actually hearing anything new myself. (Of course we have to listen for ourselves. But, I believe that when you understand someone’s sonic preferences, and you have calibrated your preferences to their preferences on equipment you both have heard, then it is possible to triangulate meaningfully on, and understand, what they mean what they discuss components you have not heard.)
I have had my VTL MB-750s for something like 18 years and I intend to keep them forever. I know well that Luke and Bea and many owners of Siegfried IIs consider the older generations of big VTLs dated sonically. For my purposes and preferences I do not necessarily agree.
I am sure the new generation of VTLs, with bigger and better power supplies and transformers and capacitors, exhibit flatter frequency response and better control over woofers and more extended high frequencies. But I like a bit of high frequency softness and roll-off. In any event it never occurred to me that I would ever consider a different amplifier.
Then I began auditioning ribbon-based panel speakers (Genesis, Gryphon Pendragon, re-built Apogees). And then I began listening to horn speakers driven by SET amplifiers. I now understand the attractions of SET amplifiers.
So I wanted to investigate whether I might prefer the sound of the midrange and treble frequencies of a ribbon-based speaker driven by a high-power SET amplifier to the sound produced by my VTLs in triode mode.
The NAT amplifiers obviously are beloved by many Europeans who have heard them or own them. From numerous reports the KR amplifiers, too, are extremely highly regarded. The NATs and the KRs seem to represent a close and fascinating contrast.
On the one hand I like that the NAT Transmitter and Magma are all-tube designs. On the other hand I like that KR manufactures their own triode tubes designed specifically for audio, rather than pressing NOS transmitter tubes into audio service as NAT does.
From the posts on this thread I believe there is a reasonable consensus that the KR -- with its “reverse hybrid” transistor input and driver stages -- exhibits slightly tighter grip in the low frequencies, and may have overall slightly greater “slam” and dynamics, among other desirable characteristics, compared to the all-tube NAT. But there also seems to be a consensus here that the NAT will sound a smidegeon warmer than the KR.
My application of an SET amplifier to power only the midrange and tweeter drivers of a ribbon panel speaker would mitigate the low-frequency advantage of the KR over the NAT. Plus, purely philosophically, if I can stay with an all-tube design then that is my preference.
So who says audiophiles cannot agree on anything? I think there is a statistically significant consensus on this thread that all-tube NAT is a bit warmer than the KR SET which may be a bit warmer than VTL push-pull in triode mode which (according to Michael Fremer) is a bit warmer than the big darTZeel. So there is some agreement on at least part of a tight spectrum of amplifiers at a very high level of sound quality and equipment which straddles the tube/solid-state sonic line.
Since I would be looking for a new amp to power only the midrange and treble drivers of ribbon speakers above 100 hz (Genesis) or 200 hz (Gryphon Pendragon) the low frequency advantage of the KR over the NAT would not help me in my particular application.
If I were to try any new amplifier for this specific purpose it would be the NAT Magma New.
PS1: Where exactly Jadis amplifiers fall in this group of amplifiers remains a mystery to me. But since I would want to try an SET I would focus on NAT and not on the push-pull Jadis.
PS2: If we were to expand this tight, high-power, SET-based discussion beyond NAT and KR to include Lamm and Ypsilon and Aesthetix Atlas, I fear any consensus about sonics would collapse quickly!
Interestingly nobody mentiones the Kondo sets. To me the Gakuohs set amps of around 22 watts deliver enough power in my Tidal LA set up in my view but if I remember correctly Ron you would have preferred (somewhat) more power. Have you ever considered the 50 watts Kondo Kagura amps? Apparently the Kagura's are able to deliver enormous power.
