ok...thanks. i turned off CD player, sub and tv. so only DAC, pre and amp. still had hum.
meanwhile, the static remains there even with DAC off (pre and amp on only)...as Microstrip said, 2 different problems!!! The static disappears with the pre on mute...but that was not the case when i had a different amp in place with the same pre (whcih is brand new). maybe a bad interaction between pre and this loaner amp i have while the main amp is in for repair?
If you are looking to ground loops you have to disconnect the units - not just turning then off. Otherwise the loop created by the signal cables grounds and/or ground wire of mains cables is still there.
