Turntable static
AWZ1979
49
21
15
44
How can I get rid of (or at least reduce) turntable static? I’ve been hearing a good amount of pops while playing my records lately. I’m assuming it’s a static problem with my turntable and/or stylus cause it’s happening with every record I play. The records are clean so I know it’s not a problem with dirty vinyl or excessive dust on my records.
CKKeung
3,063
3,201
1,410
Hong Kong
labjr1
33
10
8
61
Reactions: CKKeung
labjr1
33
10
8
61
An ultrasonic cleaner will remove static.
Only until you start to play it. The friction of playing the record creates static electricity. I wet cleaned my records and used a Zerostat and still had static issues. I didn't want a noisy humidifier that required constant maintenance, so I opted for the DS Audio Ionizer-001. It constantly keeps the record at a neutral static charge while playing the record. It is pricey ($1800 US) but effective.
AWZ1979
49
21
15
44
The problem seems to have cleared itself up. I guess maybe if a record that has a lot of static on it is played it can cause some static to linger on the turntable for a while but it eventually goes away.
CC61231
4
5
3
52
I have (had) the same issue with excessive static charges on the records playing on my Bergmann.
Using a static 'gun' like Milty helps to some degree, but the cure came when I invested in a Dyson aircleaner / humidifier.
Setting the humidity to 40% or 50% makes a huge difference to the 33% that we had in the house before.
// Chris
