Hi Mike, your thread http://www.whatsbestforum.com/showthread.php?18648-The-best-way-possible-to-build-an-active-system&highlight=acourate from a few months ago has set me off on a journey to update my system with a new digital crossover. I thought I would start a thread, describe my current system, and see what you think.
Current System
Three way active horns with a two subwoofers. Currently set up like this:
SACD player --> Preamp --> Active crossover --> one amp channel for each driver
The active crossover I am using is a Marchand XM-44. I also have a DEQX, all it is doing at the moment is providing room correction for the sub. I find the DEQX to be unsatisfactory in my system, as it does not have enough drive to power the inputs of the power amp (!!), even with the dip switches set for maximum output (an undocumented feature).
Aim
My new setup will look something like this:
SACD player (now as transport) -- (digital) --> PC --> Multichannel DAC --> one amp channel for each driver
As you can see, I am contemplating two purchases - (1) a custom built Windows PC, and (2) a multichannel DAC. I have the following aims:
- the PC needs to be powerful enough to run Acourate, Roon, and HQPlayer simultaneously. The PC will now function as a digital crossover, using Acourate's crossover generation function. It also needs to be powerful enough to do all these calculations at Quad DSD resolution.
- I would like to retain the ability to play my large collection of SACD's, although I don't see how I would be able to. The SACD player (Playback MPS-5), like all SACD players, has proprietary encryption for DSD out.
- the Multichannel DAC will replace both my existing DAC and preamp, so the DAC has to be sufficiently high quality (i.e. equal to or superior to the MPS-5), and the preamp output section MUST have enough output voltage to drive my power amps satisfactorily.
Questions
1. In your other thread, you suggested a Merging Hapi or NADAC. I have since found out that the NADAC benefits from a preamp. Furthermore, I am not keen on the learning curve involved with computer networking which is apparently required to get the NADAC to run properly - so this rules it out. Are you aware of any high quality multichannel DAC's that would fulfil my requirements (i.e. DAC equal or superior to the Playback MPS-5, and proper preamp output)?
2. How do you get 8 channels of digital signal from the PC to the multi-channel DAC? Will I need a sound card with 8 channels of digital out? Do you know of any?
3. Do you know of a way to get this setup to play SACD discs? Or is the only way to experience DSD to download hi-res files from a service like Tidal?
4. Is it possible to get Acourate to "pre-convolve", or getting HQplayer to "pre-upsample" the audio files to cut down on on-the-fly processing? (Therefore generating larger files, but saving CPU power, generate less heat, less risk of dropout, etc).
Current System
Aim
Questions
