I am more interested in the comments by users that have the unit, as well as the Mini DSP and the Beringer I think it wass.
I used a DBX223 for a couple of years. Not bad for sure. The sublime audio I replaced it with has a significant improvement however.As a data point if you want a low cost crossover to experiment with take a look at this DBX 223. I have one in my 4 way analog active set-up and it's fine. Even using with compression drivers the noise level sighted as a possible issue is not in my set-up. It's a simple 2 way there is also a 3 way version available.
Rob
dbx 223xs Crossover Review
This is a review and detailed measurements of the dbx 223xs active analog balanced crossover. It is on kind loan from a member and costs US $245. I must say this is a nice and sturdy package for such a bargain price. Controls feel nice as well. Functionality though is confusing given the...www.audiosciencereview.com
Again, for a digital only system, the Mini-DSP Nanodigi and your own DACs works very well and is very easy to use and to dial in a system. I went analog active only to accommodate my turntable.And questionable measurements. Someone in the comments said his test equipment can create the noise. I don't know if it true or not, but Amir does not have a proper tool basket nor the technical expertise to measure much. He have very crude and limited techniques. He is only giving a small data point.
NanoDigi needs dedication DAC on the output.Again, for a digital only system, the Mini-DSP Nanodigi and your own DACs works very well and is very easy to use and to dial in a system. I went analog active only to accommodate my turntable.
Yes, I said it needs your own DACs. So, if you have only 1 DAC get a second one for a two-way setup.NanoDigi needs dedication DAC on the output.
I also looked at the MiniDSP SHD but that is 4 mono out. I need 3 stereo or 6 mono.
The Ashley Protea or some of the Yamaha have 6 outputs. That would allow me the flexibility to Tri Amp.
You got it the other way around. Signal before the power amp is low current driving high impedances. Signal after the power amp is high current driving low impedances. High current means higher losses. The use of inductors in passive crossover networks also introduces hysteresis losses and complex interactions with the back EMF from the drivers.Let me see if I can break this down.
The signal from pre to amp is small and delicate. So minimal devices are audible when inserted into it.
The signal from a power amp to speaker is robust, so more can be put in its path. But its still audible.
Yes, the preamp output would see 100kOhms load. Whatever load the crossover is driving is not seen by the preamp.If I put a active crossover between the amps and pre, and the active was 100kOhms on the input, would my pre see 100k ohms?
What is wrong with using opamps?Marchand also makes full Tube and also passive line level crossovers...no need to go with an op amp based solution from them...
I'm going off what OCD Mike says. He said something along the lines of op amp can be a little hard and mechanical sounding. He had a Marchand tube unit made up for him, but I never saw him use it and describe the difference between it and one with op amps.What is wrong with using opamps?
I would argue the sublime audio offering would be more transparent Vs a Marchand tube crossover no?
I've got directly heated triodes in my dac, preamps and power amps and I would far rather have a solid state analogue crossover Vs one using 9 pin tubes adding unwanted distortion.
Happy to be told my argument is incorrect but that's my thinking.
Sublime is analog? Just in the signal, not speaker path.I am extremely sensitive to "mechanical" sounding equipment, that glassy sound of cybals and piano can ruin the listening experience. Having listened to quite a few digital (horrible sounding) and pro audio analogue (add a veil and reduce resolution) units I find the Sublime audio analogue crossover totally transparent.
Possibly because their SNR and THD numbers are crazy low.
Nonetheless, given I'm never selling my magnepan 20.1s I am always open to even better analogue crossovers so might reach out to Marchand and see what they say.
The sublime audio unit is analogue, no AD conversion. I've also used DBX and Behringer analogue crossovers that were very average indeed. I've also used Behringer and Monacor digital units. The Behringer was laughable bad. The Monacor DSP was actually pretty transparent but I had two fail on me plus the Sublime unit is better.Sublime is analog? Just in the signal, not speaker path.
I have had the following analog active crossovers:The sublime audio unit is analogue, no AD conversion. I've also used DBX and Behringer analogue crossovers that were very average indeed. I've also used Behringer and Monacor digital units. The Behringer was laughable bad. The Monacor DSP was actually pretty transparent but I had two fail on me plus the Sublime unit is better.
I use it after my type 45 preamp to split the signal between my Atma-shere OTL monos and my bass amps that run the bass section of each panel. I don't use subs. Unlike the 20.7, the 20.1 have huge and heavy external crossovers that can be removed for active running.
Having spent a vast amount of time trying different combinations of streamers, DACs and network connections I was able to finally achieve a total analogue sound for around $15k total outlay. This is using Qobuz.Sublime is analog? Just in the signal, not speaker path.
I bought an album I like on Qobuz and downloaded it. Then access the file through HQ player. Last night, I was comparing the downloaded file to streaming through Qobuz. While they were close, I know exactly what you mean when hearing cymbals and piano. HQ player is better.
I know, I know. I can spend $100,000 on Taiko/Lampizator to get rid of that noise. Or I could purchase a $6000 switch and another $5000 in LPS to power my modem and router.
I could buy the Schnerzinger gear for $20k
I'm sure it would all help streaming.
I could also redo the electrical to the room I'm in. Currently it's far from optimized.
That's a kind offer, thank you. Where are you based?I have an extra two-way Marchand XM44 crossover if you're interested, but you must do a shoot-out between it and the Sublime and report back
I replaced it with a three-way XM44, so it's just here collecting dust. I use the Marchands on my 3.6Rs.
I went with the Marchand XM26 crossover because it is the simplest active crossover that I could find. It uses eight tubes total. I’m using new Genalex Gold Lion 12aX7 and 12aT7’s. This system is just as quiet with unbalanced interconnects as it is with balanced interconnects. No need for the added complexity of a balanced unit here.Thx for that useful info! I am really curious about the tube xover because I have been thinking about this for quite some time.
