It' s not impossible - let' s make a list.Thanks Marslo, if we can do SET amp comparisons, I will be down in a flash
Ok guys, that was one exhaustive write-up, and don't think I have done justice to it. Anyway view this as the first part. Not only do I expect to update this after reflection, but future trips will clarify a few things further
http://zero-distortion.org/the-italian-over-the-top-road-trip/
Most of the stuff was written on the same day and at the airports, to be honest to memories and impressions. It is the pics loading, and sectioning that takes more time.
The key learning was that Yamamura aside, if you want to set up a system for music, you have to get speakers that disappear in your room, small speakers, that you can pull right in to create depth and stage.
Most audiophiles really need to revisit their concept of what is a ‘big’ speaker – a normal floorstander might be a giant speaker for your room, in case you are thinking it’s only the Alexandria or Grande Utopias that constitute big.
Imagine, a B&W 805 has sent Marco back to try and reposition his Alexandrias to get more depth and stage behind the speakers. Gian too will be trying to pull his Montagna a few feet in and later try to move his rack out from the middle.
To recommend a general standamount over some exotic giant speaker is the best way to make an article boring, but I cannot stress how much reality disturbed us.
(...) That is why I would want a system with large speakers only in a very large room. Some have suggested that my room (24 x 12 x 8.5 feet) could accommodate larger speakers. To which I say: Forget it.
(Again, all IMO of course).
For many years I had Wilson Audio Watt/Puppy 7's in a smaller space (18'x11'x9') and it sounded great. The speakers disappeared completely when used with the proper equipment (at that time conrad johnson and the Forsell CD air transport and matching DAC - the Transparent Reference XL cables were also mandatory).
Is there any explanation for the B & W 805 performance? Considering the room long and narrow I question how they could have excelled?
It was space behind the speakers and positioning at the right place. It was giving a seamless soundstage that started behind the speakers, and came through to the listener as if there was no speaker in between. There was reasonable speed and bass slam. Excel is probably a strong word, but it did basically make us ask the same question you did, why don't we get this seamlessness - there is a continuity of sound through the room - with better speakers, and it is just placement. Also in these rooms the bass does not over load and that probably leads to the clean sound. In ordinary rooms, simple and small might work better than big and bold
. . . Whether this can be achieved by standamounts, Sabrina, or whatever, it is important to have speakers you can pull in, get that soundstage behind that flows through to the front, with speed and slam. Timbre will change with speakers and electronics, but a bigger size could affect the layering, cause bass boom, and make it sound as if coming from the speakers.
1) Yes - I feel that we learned about the importance to soundstage of pulling speakers from the front wall and into the room from our dipole speakers. The soundstage often develops from behind the speakers. I would always start by placing dipole speakers 6 feet or 7 feet or even 8 feet into the room. (I still think this may be why I either I don't hear soundstage depth, or because of their physical proximity to the front wall I simply visually trick myself into thinking I don't hear soundstage depth, when horn speakers are at or all close to the front wall.)
2) Mike L's front wall/loudspeakers/listening chair configuration shows that even with a great amount of listening room length a speakers-pulled-out and listening-position-close-in configuration might be best.
3) But attempting 2) could occasion driver integration problems with some speakers if you're sitting too close, and, as you suggest, attempting this with large speakers in smaller rooms could create bass overload.
4) While I always have pulled dipole speakers well away from the front wall and into the room, rightly or wrongly, I have then liked the distance from the midpoint between the speakers to the listening position to be about 1.5 times the distance between the speakers. Maybe that has been wrong all these years and I should gave been listening closer-in.
The fact is I have never had the patience to experiment the way Mike L did and Marty did and now is again with tiny changes in speaker location and listening distance. (I am not going to make this mistake again, and I know I'm going to spend a very, very long time getting the Pendragons placed optimally.)
I ve been reading a bit about acoustics lately , being the the last step the room lol .
Afaik acoustic engineers overhere prefer the ceiling to be higher then the distance to the sidewalls , so the reflected sound of the sidewalls arrivers earlier then the reflected sound of the ceiling .
This will then improve hearing a stereoimage as the hearing doesnt get mixed up , not that that is possible in my situation but talking more of a ideal situation.
Talking theoritically without adding absorption /diffusors
I got it from this video but its in dutch , they are a worldwide known company and design or redesign some of the most famous halls , its called peutz
https://www.youtube.com/watch?v=YK1-9Z-G1dY&t=15s 6,50 in the vid
i ll try search one in english
its about scale models used in designing halls
https://www.youtube.com/watch?v=MIwneKfddAE
