Long time lurker, first time poster!
With the current alpha line discounted pending new line around the corner (or so I understand), I see this as an opportunity to upgrade at a reasonable cost. Sigma and power conditioner products not in budget right now. I have alpha HC to PS8/Defender to alpha HC x 2 to my Bel Canto Mono Blocks - so I feel OK there. But my DAC and preamp don't have the same level of power cord quality (preamp has Venom HC and DAC has a cheap Isotek). In addition - I have good IC from preamp to amp (python zitron) but cheap IC between DAC and preamp (Audioquest Red River - I know!).
It seems that the forum here supports the notion of upgrading AC before IC...and with in mind my options are:
1) Alpha Digital to DAC and Alpha Analog to preamp (cheapest option and I almost pulled the trigger....) but I have read/heard/been told that the alpha HC is in fact superior to these others (best buy!) so I am instead considering....#2 below
2) Alpha HC to both preamp and DAC - a little more expensive but perhaps more flexible and better performance
3) Some combination of the above? DAC first?
4) Or should I upgrade the DAC to preamp IC first?
It's probably just a few hundred bucks to go all alpha HC (option 2) so if enthusiastically recommended I'd consider that. On the other hand, seems like the wise folks at Shunyata did in fact build these specific cables for these specific uses - so if sound quality not hugely different I'd go the digital/analog specific route and save up for a Denali
Thanks in advance for consideration of this newbie question!
P
P
