USB cable recommended?
I received my Audience Front Row Reserve USB and after getting some time on it I must say this is the best my system has ever sounded. I got what I was hoping for compared to the AQ Diamond. I got the same detail, yet not edgy or lean. It added more midrange warmth, texture and tonal balance which was what I wanted. Soundstage presentation is so much better defined, layered, and bigger than the AQ. I believe this to be a very fine cable worthy of their top level at Audience.
Since my native language is not English, I apologize in advance for some incomprehensible parts.
【SOUND】
Usually there are two or three songs at once. If you don’t like it, there is a high probability that you won’t be satisfied in the future.
The sound performance of Sinope has obviously surpassed the USB performance within 1000$, and is tentatively rated as the S level I have heard.
First of all, you will notice that the low frequency is very deep and impactful, and the low frequency is rich and slightly warm.
The sound bottom retains the liveliness of the previous generation Callisto, while also enhancing the musicality and realism.
The colors are fuller, the positioning is more accurate than Callisto, and the details are not as polished.
Then use the wind instrument, which is relatively weak on the system, to test it. The end rhyme and high-frequency luster are both stronger.
Especially the smoothness of the music is so good that people can listen to it one after another.
I often almost forget that I am seriously testing.
Usually when I listen to a USB with strong musicality, either the details are smoother, or the whole thing is diffuse and blurry.
Sinope can maintain such clear details and rich low-frequency layering despite its strong musicality and liveliness.
It really surprised me. The weak point ~ I may have to wait until I hear a higher-level USB cable to tell the difference.
Or the sound direction is different.
【Compare】
It’s time to offend users again. Let’s talk about some horizontal comparisons. I can only give examples of a few with familiar voices.
(PS: I have heard at least 10 different brands and models at home)
I won’t write it down if I’ve heard that it’s not good enough. XD, A-level and above are pretty good.
Because everyone’s favorite music types and needs are different, I won’t go into too much detail, just briefly describe the key points of what it sounds like on my system.
If it sounds different to me~~then I won’t refute it
[A-level]
1.Entreq Konstantin Infinity usb
It's loose and natural, and the vocals are quite neutral to me. The disadvantage is that there is a slight lag, like
Stepping on the dirt of the country road after the rain
2.Crystal cable DIAMOND2(1) usb
It has a glossy feel and excellent high-frequency extension. The disadvantage is that it is thin and especially has too little low-frequency content (I personally don’t like the sound direction of Crystal).
3.Vertere pulse-b usb
Slightly sweet, warm, and airy. If you like human voices, it’s a no-brainer.
The disadvantage is that there is less low frequency and the lines are not too solid.
4.Final Touch Audio "Callisto" usb
I have been using this model for two years. It has excellent smoothness and airiness. The disadvantage is that the low frequency is too shallow and powerful, which is not enough for EDM, so I upgraded to sinope.
5. Triode Wire Labs "Passion" usb
The three-band is very balanced, powerful, detailed and positioned. Its advantages and disadvantages are all neutral and it has no special skills. It is too powerful for its price.
[[A+level]]
6.Stealth Usb T Select V3
Great sense of space, very dark background, average male and female voices with good appeal, not very sweet type
Disadvantages: Adjusting the position of the ring on that line will affect the performance, revealing that the force is high and not too tolerant.
7.Audience Frontrow usb
After listening to it for a short time, I found it to be soft and detailed, solid and thick, with a good sense of envelopment. The vocals are not as sweet compared to Little B
It has a smooth and charming feel, but its shortcomings are the sense of lines or the sound quality. It would be better if it could be a little higher.
[[S level]]
Usually at this stage, it is very comprehensive and it is not easy to find shortcomings. It depends on whether the direction is suitable. There is no weak point.
A.Vertere pulse-HB usb
The overall sound is fuller than the small B, and the low-frequency volume is sufficient. It is more musical in the S level.
The texture of the strings is amazing
B.Final Touch Audio Sinope usb
To me, the musicality and acoustics are quite balanced, and the flow of the music is super good!
C.Shunyata omega usb
The sound field is vast, rich in details, the background is extremely dark, the sound is full, and the overall sound is more acoustic. I think it will perform better in a speaker system.
【SOUND】
【Compare】
[A-level]
[[A+level]]
[[S level]]
My USB cable journey is limited. I used a Curious Cable USB years ago and moved up to the original Network Acoustics Eno USB. About a year ago I tried the FTA Sinope USB and agree it is amazing and agree with your description. I was able to compare the Sinope to the Callisto and found the difference to be far greater than the extra cost.
【SOUND】
【Compare】
[A-level]
[[A+level]]
[[S level]]
The Sinope is my favorite USB cable by a wide margin unless one wants to spend big dollars with diminishing returns. I have often used and heard this cable, most frequently with Lampizator Baltic 4, Horizon, and the Posidean.
Agreed it is an excellent cable. If you want to move up a price bracket, try the Tara Labs Master!
Reactions: ZoranZu
Just placed an Infigo USB for sale on the "Gon".
It is also on AudioMart
ozzy
I have an extra Stealth Audio Double-Tune USB on AudioMart if anyone is interested.
It is my Reference USB cable in my own system!
ozzy
What are you using now out of interest?
Oh yeah, since my Lumin X1 can receive optical direct, very nice improvement. The Infigo is very good for those who must use only usb.
ozzy
The Grand Master USB w/HFX Ground Station is on the way to audition, I’m really scared because I can’t afford it
Yeah I listened to one of those too. Had more clarity than the Master to my ears but felt it didnt have quite the same life. The imperfections in the Master were actually quite pleasant.... YMMV....
There are two types of USB, Grand Master and Master. Do you like Master better?
I think the Master is better value than the GM. As I said, the GM IS clearer, but maybe a fraction thin (obvs system and preference dependant) but for my personal preferences and budget I stuck with the Master. So its a personal preference thing, cant really say that enough!. The Master is excellent, a noticeable step up over the FTA Sinope (a highly rated cable) for example. See https://www.whatsbestforum.com/threads/usb-cable-shootout-8-cables-tested.37488/
Thanks for the reply, it’s very valuable, then I should try both USBs at the same time!
Reading the forum in last several weeks/months it seems to me that USB type of connection is somewhat becoming or it already is a second tier connection type where more and more users are choosing good old spdif or eas/ebu (me also using spdif often) while other with the units capable of i2s are pushing for the crystal clear signal via this one. I won't even mention XDMI of the Taiko/Lampi latest developments. Still some still use good old USB hence its worth to explore viable options in this domain.
After living for years with FTA Callisto and Sinope I've sized the opportunity when I was receiving back my units from Edisoncreation to order his reference USB cable. Not to write about the spec I'll just do copy/paste of the specification and basic info from the website which is located here: https://ediscreation.com/product/reference-silver-usb-cable/
Specifications:
- Perfectly Polished 5N Sterling Silver Cores:
The cable features impeccably polished 5N sterling silver cores, offering superior conductivity and signal purity.
- Independent Insulation: The cable is designed with independent insulation material that effectively reduces crosstalk, ensuring clear and uninterrupted sound.
- Special Spinning Shield Construction: This advanced design feature further enhances signal clarity and reduces interference.
- Special Isolated 5V Shield Construction: This feature effectively isolates the voltage, reducing any possible interference and enhancing audio quality.
- Carbon Isolation Technology: This advanced technology further minimizes interference, ensuring a flawless signal path for your audio.
- Custom-Made EMI Block: A specially designed EMI Block reduces electromagnetic interference, ensuring pristine and uninterrupted audio transmission.
Look and feel:
Cable is packed in a very very neat box which gives immediate feel of the premium product. Cable as such is as well looking impeccable and you can see attention to details in the production. It is very flexible which in my book is a huge plus.
Sonics:
Break in with the standard ups and downs lasted for good 100+ hours which I expected and was advised by Edison about it I did not pay too much attention to overall presentation but the cable sounded good/great from the get to.
Now as I've been using it for the last good two months I can with confidence say that this particular cable is ticking my USB cable boxes by any means and definitely is a keeper. It is extremely fast, reveling and detailed but not on the fatiguing side but rather in a pleasant and musically engaging way. Nothing is popping out of the picture where it should not, vocals & mids are seductive and in the "room" somehow. I always like to mention "extensions" and this cable is excelling in this regard. Bass is deep and firm while high frequencies and super nicely extended while tonally it is also spot on.
Actually if I roll back the film a bit in my head - it brought me back to the beginning of my story - I'm again daily using USB connection which i scrapped for the slight superiority of the spdif one.
Price:
I'm ashamed to mention it, as someone or even many, will say that this price point has nothing to do with "reference" product, being used to pay in numbers with close to, or with minimum three zeros after the first number.
Well this particular one starts for a change with zero followed by dot and number 4 and k (0.4k). Yes - its a real deal in this insane audio price matrix we live in. If you have a need for this type of connecting cable make sure you give it a try!
King is dead long live the king! Pure bingo by Edison
View attachment 125873View attachment 125874View attachment 125875
Are you still using this USB cable? How does it compare to the FTA Callisto?
I was using the Edison USB cable for a few months. I've recently gone back to the Snake River Audio USB. I found the SRA to have better attack and expansiveness of sound stage.
Reactions: Campo007
Has anyone tried the WireWorld Platinum usb? Or perhaps the AudioQuest Diamond usb?
Fairly pricey but based on the improvement with the Pangea it may be worth it.
ozzy
I’ve tried both. Kept coming back to A.Q. diamond. Has a natural sound to me. The W.W. Was too bright for me.
