I agree completely and will be doing such in my new gig
nice!!!
We could line the room's circumference with Gothams!
What about the Paradigm SUB2? 4500W RMS on a 220 line. 6-10"woofers. More air moving capacity than a Gotham.
They don't get the same amount of press, but I bet in a head to head, they would do just fine against the Gothams. Plus, I like their symmetrical radial design..
They both get the same exceptional editorial reviews.
This is an opportunity to look into the fabulous world of proper bass reproduction once you go multi subs you can't go back, ask Steve
G-O-T-H-A-M
you'll never look back
JL Audio will do 1,2 and 4, but not 3 or 5
It would be interesting to know at what frequency your Wilson's roll off in your room. An adjustable sub is great for fine tuning and smoothing out the bass response even if your main speakers go deep. Especially if your main speakers don't have adjustable bass.
Don't forget the other benefit that many are OK with inserting some device capable of applying some electronic correction to just the subwoofer. This can be a huge benefit in getting a subwoofer to play nice / seamlessly integrate with a 2ch system. Add a measurement system for less than many spend on cables or isolation devices, and you can even see what happens with all the different possible subwoofer locations.
How does the setup of the JL Gotham work?
The reason i ask is that what i like about Velodyne is that it gives me the ability to:
1) change the high-pass crossover level from 20hz to 200hz,
2) rolloff from 0db to 48db to blend that crossover point
3) It also gives me 8 frequency markers i can move up and down the spectrum and either boost or decrease by 8db. you just select the marker...move it up or down the frequency spectrum and move it up 8db or down 8db in 1db increments.
4) change phase
5) memorize up to 6-7 individual pre-settings (i only made 2...music or film)
So, what was wrong with the Velodyne?
