I have had a 60 inch Panasonic plasma TV for over a year. It comes with a standard black power cord with a moulded male plug. The IEC end is different though. It has a clamp and locks into the IEC on the TV. The Panasonic manual warns to not use any other power cord (heat and fire risk). I did try an upgraded PC when I first got it. It was a cable by another cable maker with a large round Marinco IEC plug. It fit somewhat loosely in the TV because the Marinco IEC plug was to big and the plug was not fully inserted into the TV. I got a warning message on the screen about heat!
I immediately replaced the cable with the stock one. Now a year later, I have read about people using the Venom 3 on their plasma TV with good results. The Venom has a small IEC plug that would fit completely into the small IEC opening on the TV. Since the connection would be solid, I believe there would be no risk of overheating?
So I have 3 questions:
1. Would the Venom 3 be safe if it fits completely onto the TV?
2. The stock cable has a ferrite ring on it. Is this just a cheap way to shield from EMI/RFI on an unshielded cable? Will a properly shielded cable like the Venom 3 compensate for the lack of ferrite beed?
3. The Venom 3 has a ground pin on the 3 pin connector. I remember when the cable was new it had a message that said the ground pin wasn't connected (this is from memory 2 years ago, I might be wrong about this). Does anyone know if the Venom would ground the TV? Any problems if it is not grounded?
With this many questions, and some apprehension, some of you will probably say to just keep the stock cord on the plasma! That makes sense. But, if I had never asked any questions and overcome some doubts, I would still be using all stock cords plugged into a duplex multiplier (the kind they sell for 4.99$ and allows you to plug 4 things into a duplex)…
Also, I have noticed that something as simple as upgrading the stock wall receptacle improved picture quality on this TV and the one before it. So, it seems reasonable that a better PC would do the same. I also have 2 good power cords collecting dust and not in use...
