Steve williams
The sociology part relates to ad hoc skepticism in audio forums, but it's not worth going into further.
You're right, it's not
If it comes from the factory now with an AHC umbilical I think that speaks volumes.
Instructions say to use the best cable you can and to pair that with the same or something similar for the Triton or even where some of us have a Typhon and thats with amps. I am now using a pair of AHC PC's for my amps and a pair of Anaconda umbilicals. It would be an interesting experiment for me to compare those with AHC umbilicals
Thanks for the report, John.
I can't wait to try the Triton and Typhon. Love all the Shunyata gear I've tried so far.
Just this week I received a Typhon and it was indeed packed with the typical white Power Snakes box that contains what is labeled on the box as the "Typhon Umbilical", without reference to a AHC PC....
Hi, may I know if you purchased the AHC umbilical cord separately or the cord is provided together with the Typhon? My local dealer told me that no cable is provide with Typhon.
Thanks.
From my readings, it was the recommendation of Shunyata that the best quality PC's should be used for the Triton as well as the umbilical from the Typhon to the Triton. What I also recall reading is that the length of the umbilical has been determined to be what it is based on best sonic performance
John
I'm shocked that your Typhon isn't on Stillpoints
Ahh, but it is on 4 - Ultra SS replacing the rubber feet. You just can't see them in this pic. Notice the USS under the Hydra?
John
nothing short of Ultra 5's under the Typhon John
Many times my bank account says "Oh no you don't", and this is one of those times! I just wish I could speed up the burn-in but I'm getting over that. I will say that Grant's comments about burn-in seem spot-on as what he's written is what I am living right now. After about 3 days, the top end just disappeared but the following day it was completely different. I haven't had the system on since Sunday and expect to listen a little tonight so I am anxious to learn how it will sound this evening.
John
I found the Typhon to require far less burn-in than the Triton
I am about to order the Typhon umbilical but I have a little problem... it's going to be shortest and most expensive power cord in my system... I have a problem with that.
