You would care about the quality of the source material because the limit of the dsp engine is insignificant - unless it's not for you. I cannot hear the dsp channel mixer doing anything bad. It nulls to absolute zero. The inverse function brings the original tracks back bit perfect so it's really hard to explain what possible limit it could be imposing on your system other than you don't like the intended effect no matter how perfectly it is executed. There are ways around the dsp or any mixing for that matter, but if you prefer 2 speaker playback on 2 channel recordings then there's no reason for you to do anything extra. I've read plenty of reports of people not liking crosstalk elimination or not hearing anything much different at all from it so I know it's not for everybody. Some people even intentionally introduce crosstalk on headphones to make them sound more like speakers. I don't get it, but it's their ears, not mine.you completely lost me right there.
why would i care about the best possible analog and digital sources, if i'm going to be limited in performance by the dsp engine? unacceptable to me in my 2 channel room.
my system building culture would be turned upside down with your approach.
i could agree that at modest performance levels that your approach might be a preferred net benefit. heck yeah, dsp everything. but not at the highest levels of media and sources.....and rooms. and the best preamps are not 3 channel, so you are restricted there too, in your preamp<->amp interface. big steps backwards.
i can see a three channel tapes and three channel systems being superior. but that's a pretty small music universe to invest in.
My only reason for bringing any of this up was that MF is using those in-ear microphones and those should be able to record the tonal difference between a dedicated center channel and a phantom center image. If someone could demonstrate the two sounding nearly identical that would raise my eyebrows and make me re-think my efforts with upmixing.
