Wave Kinetics NVS
dminches
3,481
2,859
1,410
Does anyone else have an issue with the NVS screen powering on? My issues started a month ago. This is a known issue since there is a replacement being developed. Unfortunately, the replacement isn’t free.
I am wondering if there is any work around. The screen is responsible for starting the platter and changing speeds.
  • Sad
Reactions: christoph
gleeds
787
1,284
235
David, I have a fair amount of experience with the NVS. Unfortunately, I do not believe there is a work around other than sending the table back to the factory and suffering the expense of the modification to accommodate the new differents sized replacement screen. With Jonathan's passing Ed Sudario, in Anaheim Hills, CA is handling Wave Kinetics. If you PM me I will gladly provide Ed's contact information. Good luck!
dminches
3,481
2,859
1,410
Thanks for your response.
I have been in tough with Ed who has been very helpful. Do you have a picture of the new screen?
Ed is planning on sending me a replacement kit for home install.
gleeds
787
1,284
235
Glad to hear Ed has been helpful. He is a great guy! So glad you can do the swap at home. Best of luck.
dminches
3,481
2,859
1,410
dminches
3,481
2,859
1,410
  • Sad
Scott Naylor
172
167
115
We need forum care packages that can be sent to members suffering like this through no fault of their own!
dminches, I’m afraid all I can do is +1 Mr. Lavigne's message above. :(
Reactions: dminches
gleeds
787
1,284
235
At least it's summer, David:)
