On this particular table , Grado Hum is an Issue .....
As I remember had to do with whether or not the table has shielded motor. That is unless over the years, Grado changed the design.
Is it really necessary to spend 5k to get a good cartridge ...? Im still pedaling between a 103R and a Grado gold ..
The A90 is the best bang for the buck bar none while you can still get one.
probably i have immortalized this cartridge in my brain but my all time fave is the ADC XLM-original version. it had the full, round, buoyant bass of the real thing, wonderful mids with wide open staging and imaging, and a top that made cymbals reminiscent of what i have heard live. it was mounted on a rabco st4 and later a grace 707.
I would agree, if one has a 30K table, anyway my question was in absolute terms, regardless of TT, is there a difference with these 5-10K cartridges , is it night and day to lesser budget cartridges in the 1K range, how was the decision made to determine which to choose, it's not like you can a/b them readily, when plunking down 10 K for eg ...
Regards,
Correct,
Grado's are susceptible to hum from unshielded motors due to their open coil design ........
We were discussing cartridges in the 1k range .......!!!
Problem here ... I don't know how to judge any cartridge in a vacuum, without arm & turntable, especially in "absolute" terms.
tb1
Sorry, my bad ...
My favorite $1k or under cartridge ... ? ... within my system ... I'm not even close to certain.
I'd certainly require it to have a LC stylus and boron type cantilever; amongst other issues my arm requires. I've setup a few AT140ml on budget based turntables in the past with generally fine results, but I have no doubt that it's frequency extreme limitations would be exposed within my system. I recently had a Nagoaka MP50s hooked to one of my other 'tables in more of a budget based system, with very nice results. The Ort.Black would certainly be on my short list.
That said, I'm a MC kinda guy ... so the AT33 would probably be the first cartridge I'd investigate for my current system, but obviously it's not the only option ...
tb1
Sorry, my bad ...
tb1
So each cartridge needs a specific arm ...? Table ? you see the issue at hand, cartridges take forever to be optimized , you wont even comment unless we are discussing arm and table, then how do you choose your cartridge, buy and throw away, or become a reviewer and get freebee's ..![]()
Semantics aside how is a Cadenza Black superior to a 103R and how was this determined .... ?
What about the Benz Glider?
Sorry ... I figured they cost > than $1K?
I've owned two in the past, and really did like 'em ... but they certainly have a "house sound".
tb1
Hey, you can judge accordingly, I know I prefer to comment on a cartridge so-called inherited sound based on how it was incorporated within a given turntable & arm ... which it's slaved too.
Have you not heard the exact same cart sound different on separate systems? I certainly have!
Have you not heard a very well respected / very expensive cartridge sound out of sorts compared to it's reputation? I certainly have.
Hell, I've never heard any Denon I liked, they all seem to compress the extreme frequencies to my ears, but then again, most of the turntable and arms I've heard Denons on did the same thing.
I've also heard far too many carts that couldn't be properly judged based a compromised 'table/arm and setup. I'll even go as far as saying that I've witnessed demonstrations in which a very well known hi-end cartridge was "purposely" mounted to a certain table to illustrate it's "inferiority" compared to another (which the store sold in spades).
Well, I never claimed the Black is superior the the 103r, but I can "assume" that based on what I've heard in the past on different tables. However, for me to fully comprehend the TRUE difference in sound between 'em, I'd need to hear em side by side on the same rig.
tb1
Lame that I quote myself, but ...
I should admit that everything in my system ... has a house sound.
tb1
