What comes first: listening chair placement or speaker placement?
I really agree that in order to set up your speakers you have to have a place to sit and listen. How do you poisition speakers if you arent sitting and listening to them?
what went thru my mind too. where does that sound come from that's helping you determine the bass nodes for the listening position? from a seat of the pants speaker spot.
the start is the start.
got to have a speaker playing. :rolleyes:
with all due respect to Jim, of course. i'm sure he will tell us his view.
Reactions: Lagonda
yes of course you do but it doesnt need to be perfect to move a chair around Mike or even walk through the room and speak
This all makes sense.
Interesting. Because of bass reponse and bass nodes?
I suppose also in this asymmetrical case relative to room the position of listener to both *speakers* should still be symmetrical.
Yes, you will typically have less severe reflections in an asymmetric position. And yes, your position relative to the two speakers should of course still be symmetrical for proper stereo perspective and imaging. :)
Reactions: Al M.
As the foundational system/room set-up step in RoomPlay sessions, this is also the most pervasive, appearing in different scenarios from time-to-time.
Establishing the Anchor Point – locating your optimum listening position
Why would you spend time & effort moving your speakers around if your listening position hasn't been first established, so that you will have even smoother bass, and therefore better musical dynamics – a vital step in a more musically involving experience?
The negative effects resulting from not addressing this critical issue – the Anchor Point - simply cannot be overstated (hopefully, since I keep reinforcing it). Even so, I am constantly amazed at how many audiophiles, dealers, reviewers and manufacturers – and even some well-known set-up guys – miss this fundamental aspect of music reproduction. When I see them worrying about speaker placement without having discovered the basic listening position first, I cringe.
Certainly, better speaker placement (including distance away from the listener and from walls; speaker separation; toe-in; etc.) can make a real improvement, but it will never have been as powerful as it could have been had those steps been built on the foundation of first finding the best listening position – the Anchor Point for all else that follows.
Basically, we are concerned about the effects of room resonances in the bass/lower midrange (from 25-250 Hz). These resonances are related to the room dimensions, and to some extent, the shape of the room and the contents of the room. These resonances may appear as peaks in the response (phase reinforcement) or they may appear as dips (phase cancellation).
Essentially, these peaks & dips in the 25-250Hz region are part of the sonic signature of the room. Indeed, every room has these issues – no matter how much was spent on their design & execution – issues which are directly related to the room’s dimensions, and to some extent, its shape. It behooves the listener to locate a listening area where the room is most neutral (peaks and dips are minimized by locating the position that works with the room's dimensions, rather than against it). The ultimate result of ignoring this aspect is reduced musical dynamics (and thus - reduced musical engagement) as I have mentioned.
By most neutral listening area, I mean the area in the room where the bass is smoothest, not necessarily the deepest. In other words, the room’s resonant peaks are diminished and its resonant suck-outs are less deep.
I fully agree with you on the importance of the listening position - all speaker positioning methods rely on the determination of the listening point.
Besides your book and videos I think WBF readers will find your articles at Audioexotics extremely interesting
https://audioexotics.vanillacommunity.com/discussion/13088/subwoofery-by-jim-smith
In fact, it would be great to have a sofware tool that would analyze the RTA spectra taken with REW, for example, at regular distance intervals and would tell audiophiles what is the better listening position!
BTW, when making these initial measurements where do you place the excitation speakers?
Reactions: christoph
It may also be worth mentioning (hoping it's not heresy on this forum), that following the succesful location of listening position and speakers, the next step towards even better bass is dual subwoofers. If asymmetrically placed as well, even better. Preferrably with high passed mains, aka limited overlap in frequency between speakers and subwoofers.
Final touch after that (if needed) is some careful EQ. One or two EQ points below 100hz is often sufficient for very linear bass if all that comes before has been done properly.
Does the listening position change if you are a nearfield, mid or farfield listener?
To bad so few crossovers have these features, sufficient phase settings and are transparent ! :rolleyes:
Reactions: sigbergaudio
In order to locate the best seating position, I simply use pink noise and measure it with a RTA. Before measuring, I place the speakers in the general location that I estimate they will be in. Sometimes I simply use my phone and the RTA program from Studio Six Digital - AudioTools.
Once the system set-up procedure is relatively far along, I experiment with slight movements forward & back to see if the sound is more engaging. A RTA cannot reveal the absolute best location. We listen for that. Then final setup can move forward.
I am currently in the process of setting up a new listening room. This listening room is not particularly large at 3.7m x 4.7m.
There is a loudspeaker calculator from Germany: hunecke.de | Loudspeakers Calculator
With it, the room modes in the bass can be calculated. It depends on the wall distances of the speakers and of course on the listening position. I start here as in reality with the loudspeaker positioning. An example:
Even if the reality will look different, the calculator allows a first position determination. For more Information: Planning a new listening room – Grigg Audio Solutions
Depends on what you are doing. For example I try to find the smoothest low end in room response by trying different speaker placement.
I have a general idea but the speaker placement for best in room LF response is going to impact where you are listening from.
When I do that I am walking trough and around the room listening for peaks and suck outs. I use a LF sweep from 200Hz down to 20hz. Once I get the LF "RIGHT" or almost then I will be looking for the same thing for a seat. Sometimes it work where the speaker stay sometimes not. I have an spl meter that can track the peaks and dips. I also use media.
Once I am in the seat I look for LF issues. repeat the sweep, and then adjust toe-in speaker spacing and seat distance from walls and speakers.
So I start with no seat.
Well worth the time spent! Once they are dialed in just enjoy!
Rob :)
Hi Jim,
I appreciate your contributions. What are you measuring for when with the pink noise and RTA? Thanks.
Evan
I've always measured from 25-250 Hz, as those frequency areas are where you encounter the peaks & dips that are the most bothersome room resonances.
FWIW, moving the speakers a foot or so backwards or forwards will make a difference, but not nearly as big as moving your seat backwards or forwards a foot or so. That's one of the reasons that I say find the seating area first.
It's also important to be sure you take all measurements at your seated ear height, beause if you hold the mic or other measurement device at standing face height, the measurements will be incorrect, because the floor-to-ceiling resonances will be incorrect.
Of course the speakers will need to be adjusted from the seating position. However, I never accept the seat location measurements as the final result - they are simply a good starting point.
I then want to play some music with varying, but well recorded bass frequencies. I may have to move the seat forward or backwards a bit to get the most agile & tuneful bass. I've never found any in-room measurements to be that exact with the longer wavelengths that we have in the bass.
Another question related to this subject is the supposed need for listeners to have to sit in the center seat for listening. When I go to audio shows or audio meetings at a friend's house, there is always a mad dash to the center seat. As if you sit in a chair some distance from the center you can't possibly hear how well the speakers/system sounds. I have a friend with omni speakers and he doesn't consider the center seat the only place to listen to music.
While omni speakers disperse mid and high frequencies more evenly to the sides, this does not make off-center seats much if any better for appreciating the imaging and staging of which the system is capable. There are two reasons for this:
1. If you are off center, the nearer speaker will seem louder than the farther speaker due to simple inverse square law rules for how volume varies with distance from the source.
2. The time of arrival of sound each speaker will be different if you are off center. The direct sound from the nearer speaker will arrive sooner at your ears than the sound from the farther speaker. This will skew imaging and staging toward the nearer speaker.
Time of arrival differences between the two stereo speakers (as opposed to drivers within a particular speaker) are quite audible. Years ago I owned a TacT RCS 2.2XP digital preamp which allowed the user to vary the time delay between the left and right speakers in increments of 0.1 milllisecond. Even 0.1 millisecond was clearly audible as a shift in left/right balance. It way like I'd given a balance control a sizable nudge to the left or right.
For best stereo effects (imaging, staging, envelopment) you MUST sit equidistant between the two speakers. That is why when audiophiles want to have more than one "hot seat" the choo-choo train seating arrangement is used by those in the know. This still is not ideal, of course, since the speakers only focus best at one spot a particular distance from the speaker plane and since having other people's bodies between you and the speakers also impairs imaging and staging. But it is quite a bit less damaging to the presentation than side-by-side seating where no one is equidistant from the two speakers.
I find it interesting moving the seat has more impact than moving the speaker. Is this because no matter where you launch a wave from, the reflections are so prolific, there are limited locations for the seat to not be adversity affected.
How much do room treatments impact the whole of seating and speaker location. If you start with a room without treatments, then add them, is the chair and speakers going to need to move.
Another way to ask the question is, do you have more flexibility with seat and speaker positioning in a room that has proper treatments applied to it, or less.
Reactions: drjjpdc
Most audiophiles launch a wave from their seat.
Reactions: drjjpdc
First, we set up an empty room for a suitable response, then you move the chairs and speakers to get the best response. Sometimes you move the chair a few inches, sometimes the speakers. I dare say it doesn't have to be 100% symmetrical.
Reactions: drjjpdc
