What do measurements say about SET’s
Rensselaer
575
459
275
69
A 211-based SET Ongaku tribute from Uesugi Ken (Otomon Laboratory, Japan) that I recently commissioned is finished and will be shipped soon. He sent me the following measurements:
frequency response: 16Hz-45KHz (22 watts/8ohm)
hum level: 0.2mV
THD: 5% at 22W
I am requesting advice from the experts out there. I hear that SET’s sound great because the lack distortion in the upper odd-order harmonics. Some say the distortion makes them sound good, while still others say they sound good despite the distortion.
What do these measurements tell you? To me, the frequency response seems to be very good (however my speakers can’t go that low, and I can’t hear that high), but what about the THD and hum levels, are they acceptable?
Gregm
532
383
155
France
The primary objective of that amp is to help you listen to music, so the key question is: do you enjoy the music? If you do, end of story!
Coming to the question about the measurements you posted, no - any well-designed SS will measure far better in the values you have posted above. It remains to be seen how important these values are for your musical enjoyment!
Now, the actual measurements: the FR looks good for an SET (v. good even!), the noise is above average, the THD par for the course.(Again: for an SET. ) The output power (22W) is excellent and allows you to drive a great many speakers out there (mine included).
I for one don't think (even order) distortion makes the amp sound "better" at all; it would probably sound better without it - but you can't have a 211 SET with 0 distortion AND no feedback, and if you're to have distortion it might as well be low order even harmonics...
Presumably the amp sounds good despite the high level of distortion, etc, and that's why people choose to use SETs yourself included!;)
Rensselaer
575
459
275
69
4212 tube amplifier
I preferred the sound of his 4212 tube amps, but can you even find NOS 4212 valves anymore?
Rensselaer
575
459
275
69
DasguteOhr
2,445
2,623
645
Germany
Rensselaer
575
459
275
69
Reactions: DasguteOhr
Audiohertz2
581
329
70
hum level: 0.2mV
THD: 5% at 22W
Well for starters you need a speaker with a zmin of 8ohm , best when talking SET is distortion numbers @1W , your speakers should be sensitive enuff as to not exceed 1 watt for normal Din ..
So mW levels to 1watt is what you are really interested in when discussing distortion numbers .
Regards
Rensselaer
575
459
275
69
Regards
0.3 mW at one watt.
Rensselaer
575
459
275
69
Audiohertz2
581
329
70
Ok those are the numbers you are interested in not the 5% quote to sound powerful . As you can see its a low distortion design in the mW level not high ..
Regards
