Hello, Bill. I admire your patience [along with Soundproof] in this thread. I can feel your aggravations, as it seems you keep repeating the same things. The quote above is one of these things, said many times. I would like you to know that I am in no way trying to confront, challenge or offer any kind of argument to the contrary. I'm trying my best to understand why I and others are getting height, when it has been stated many times that the recording nor the playback system can not offer this. I guess what I'm looking for is some guidance. I know frequencies, would like to think I know exactly what compression/limiting sound like. I know I do not like it every time I hear it, which is unfortunately often in my experience. Especially in today's mainstream recordings. What I may not understand or comprehend fully is all/most of the variables that contribute to a recording. I haven't been privy to that kind of exposure and how it relates to recorded music.
And that's a good thing. Also, generally speaking, if you can actually hear a compressor working (and it's not being used as an effect) it is not adjusted correctly by the engineer. It's either got the wrong attack/release settings or is being overused.
That said, I just put back in Sarah McGlachlin. The same CD I had playing the other day and the results were repeatable. Her image was mostly dead center and again, above the tops of the speakers. I try to bring the image down in my mind with my eyes open or closed and I just can not do it. Her image does not sway. This is just one example. We have many examples of other members of this forum that have well executed layouts, along with professional acoustical treatment and top notch gear. Many of them have offered observations that included height. Much more than just slightly above the speakers.
which album is this? I'd like to hear it here.
There are a number of speaker manufacturers that use some odd techniques to get a sound they want. One such technique is to mount certain drivers (usually mid-range, but sometimes high frequency) pointing at an angle upward instead of straight ahead. Depending on how they are crossed over, and the source material you listen to, when there are frequencies dominant in the mix and centered in the range of one of the tilted drivers, it can project beyond the box. I had some Vandersteen speakers years ago that did that -- it drove me nuts!
Also, the type of crossovers used, what frequency they center on and their slope can have a similar effect in some cases. Crossover networks with a long slope (6b or 12db per octave) often have to have the drivers connected to them set out of phase with others so they will be in phase at the crossover point. That means that you might have the bass speaker producing a positive wavefront, midrange a negative wavefront, etc. As the phase twists from 0 to 180 degrees through the crossover in this type of system, some funny things can happen outside of the box.
In order for JUST the vocal on your SM example to be above the speaker cabinet and nothing else, something -- a driver position, a crossover, or something else doing some physical reflecting has to be projecting that particular range of frequencies oddly. Another thing that can cause this is if bass and midrange drivers are out of phase from each other (unintentionally) and the resulting cancellations in the crossover range push the voice away from the woofer, i.e. up.
I don't know your speakers so it's hard to speciulate further. One thing for sure, it's not a function of the recording. Have you confirmed that your speakers are the same phase as each other? (dumb question, I'm sure, but you never know)
This is just for the sake of discussion and learning, again, not confronting. Just trying to gain a better understanding of what it is you are telling us as to what a recording or playback system can not reproduce. At what point shall we stop the "various system (mis)configurations"? Some of these gentlemen who have observed height have spent well over what some would consider spending on their entire rig just on professional room treatments. Some of these same gentlemen have more invested in just the speakers than many folks would spend on a small house. Yet, they observe height.
And I don't doubt that for a minute. It's just not a product of the recording. And some hear height as a product of driver placement and believe it to somehow relate to the recording. I very definitely hear height and positional information from my speakers, but only because of the distance between drivers.
So, what I'm getting at, is that you say it can't be done. Yet these systems, along with professional room treatments and years [even decades] of fine tuning their own slice of audio heaven still share "various system (mis)configurations"? With respect to some of these rigs, would you be so kind as to point out what what some various misconfigurations may be?
You know, just because of the credentials are good and they have had 'professional' room treatments doesn't mean that everything is right. The folks that have a big open live room that believe it is going to enhance the recording are undoubtedly getting all sorts of phase shifted reflections from all over the place that will influence the presentation of height. If the rooms are too small and the speakers are large or tall, there are other influences that can radically affect the sound stage they present.
I have walked into recording studios with their monitor speakers out of phase, and the engineer completely unaware of it. I've gone into another where the highs were in phase but the LF driver was out of phase. Again, the head engineer of 15 years or more was unaware. I hear it immediately, and I don't even have to be IN the room, just outside the open door in many cases.
Extending that a little further, there are a lot of 'pros' out there doing acoustics and room treatments that barely know what they're doing. Some do, of course, but the point is that it is very hard to gauge what all may be going on in even an experienced listener's system that was done by accident and he just believes it is right. You can't tell over a forum.
Here's where I'm coming from, if you will allow...The speakers are professionally built, designed and in some cases, placed in a proper location by the builder himself to provide optimum playback. The upstream gear, as you can well imagine, is all professionally built, engineered, isolated, etc. and in some cases, even removed from the room altogether. The rooms have been professionally treated by one or more acousticians. I'm having a hard time swallowing that they have "various misconfigurations", as the empirical evidence offered by these folks suggests that height can be achieved. One example offered was a height of 12' and repeatable on different days and with different observers that all agreed that they observed the same thing.
Instead of repeating the same things over and over, let's start addressing and getting into the understanding and detail of these repeated statements.
I'm not sure how that can be done without hearing the system. You have people with no professional listening experience expressing opinions based on only what they hear on their system (not directed to any specific people here), or going by what the dealer or HT room designer told them. I know it's a very touchy subject to a lot of people, but there are huge variables involved that can't be trouble-shot by description only. And you can always find a group of friends who think the system in question is just wonderful -- but what does that mean? Nothing.
As far as professional speaker designs is concerned (and equipment), have you ever noticed how every one of the high end manufacturers make pretty much the same claims about their designs? But they ALL can't be perfect, or even close. Yet you can always find someone who likes them for one reason or another. But how many are basing their opinion on how accurately the speaker or equipment in question renders the source? Not many. It's mostly personal preference.
I have a friend who has speakers that are easily 8' tall, but they contain a full height electrostatic panel on the inside of each, and a long row of alternating low and midrange drivers from floor to ceiling. It's a nice all tube system, yet there is no variable height being projected! It's a very big and powerful image, to be sure but everything sounds like it is right in front of you with width and depth, very clear, but the same height. It focuses toward you whether you are sitting or standing -- very nicely and accurately detailed.
I hope I have been objective to your questions.
--Bill
