Very much looking forward to learning more. Particularly there has been quite a lot of discussion (that I am paying attention to anyway) about subs being blended with panels and horns and just generally with SOTA reference speakers, where the subs come in under 35hz to create greater musical foundation, sense of venue (not bang-bang-boom-boom)...and often to create a more dextrous and mellifluous midrange and treble.
Part of the equation is its ability to create exactly the low-bass drive, foundation, low-distortion air movement...while not adding upper range confusion.
Part of the equation is simply air displacement...where some proponents are for greater surface area and/or greater air displacement capability where the sub and its parts (cones or panels like PureLow) are simply 'loafing' moving that much air so effortlessly.
Part of the equation is the ability to blend and have loads of adaptability into systems and particularly into different rooms.
Given that VS has spent quite a lot of time in its history on the engineering of its designs, I would be particularly interested in to learn how VS thinks about the above concepts in the context of their Shockwaves.
In my own case (system below) I have been considering 2 x dual-opposing 18" cones designed by Nathan Funk in order to ensure extreme air displacement in a room 46' x 17' x 11' but not necessarily at high volume, just at extraordinarily low distortion...otherwise, just stick with the very competent Velodyne DD18+. I also have been intrigued by the PureLow panel subs (1m' of surface area with low excursion as a panel, but apparently exceptionally well executed).
Very intrigued to learn more about Shockwave, which I have certainly looked at online more than a few times.
Perhaps, if you/they have time, you could help get us a 'commercial/technical view' from VS about how they attack the challenge. As you suggested, the Shockwave seems to be with other non-VS systems in mind as well, depending on their own capabilities and technical features. Thank you for any insights and guidance.
