Hi Ron,
Mostly coherence
I’ll use exactly the same neodymium 15 inch woofers already used for the pap horns OB but just in a narrow band application sub with isobaric loading.
Two things can potentially happen at this point I’m thinking. I’ll either find I just want to add a mild extension and authority to the paps but not forego ultimate coherence and so just integrate it all in a passive 2.5 way crossover being driven from just the one pair of 805 output tubes. The minimalist in me is very attracted by that notion of SET purity. But only by building and listening will I ever be sure.
I will also try a plan B and go active for the subs with a mosfet SS. Bill’s logic in this approach is also very much worth investigating.
I am just guessing that 4 x 15 inchers for a sub will give it the authority I’m looking for and that using the same drivers all the way from 300hz down (2 x 15 OB woofers and 4 x 15 OB subwoofers will be a good approach).
Either way I’d very much like to start simple and build up to it and enjoy the discovery of what works and what doesn’t along the way.
I’d likely try slot loading the four subwoofers before then going for more woofers. I’m trying to avoid overscaling with the subs and it’s just simply easier (and more economical) to just work upwards.
I’m a complete newb at this so just moving towards learning and having some fun along the way.
I do think that the further you reach down the higher you need to reach up so if all this lovely bass foundation requires more air to bring it to a good weighted sense of centred-ness I could then also try floating a supertweeter in on top.
So Plan C is to just then give myself a completely modular and detachable OB platform which I can then experiment with a different approach altogether for then a four way horn setup as alternative with a pair of iwata horns for a 300hz and above... so an iwata wide bander with an iwata suoertweeter. I do love the form of the iwata horns and so may just end up with two alternative horn setups. Surely two pairs of horns can’t hurt
