Tuesday, July 24, 2012
10,000 Maniacs
A lot of you aren't going to like this post. Its not about Natalie Merchants old band, but the amount of time it is acknowledged it takes to become very proficient in an art or discipline, and that is roughly 10,000 hours. Its by no means definitive, but seems to be surprisingly accurate for many endeavours.
It is certainly true for the art of critical listening of high fidelity reproduction of recorded music.
10,000 hours is about 13 years of 2 hours per day. Very few people get to listen for those sorts of time periods, and if you can only manage an hour a day it will take a quarter of a century to get to the 10K mark.
Just as much a skill, the art of critical listening is an evolutionary process, you cant go from begining in hi-fi and owning your first hi fi to having good analytical skills and the knowledge to listen honestly and illusion-free overnight.
That's the hard part- you might have 20Hz-20KHz hearing , but unless you can seperate objectivity from subjectivity and honestly process what you are hearing into something approaching truthfullness, you are a long way from the ability to critique the reproduction of music.
There are 10,000 maniacs on every audio forum giving their opinion on what is the "best" this and the "best" that. These opinions are pretty much based on how far along the 10,000 hour path they are, and the stages of evolution goes something like this:
Early on the hi fi path is the "loudness" stage- big bass , big treble. The bass is a dead giveaway , 100Hz boom gets mistaken for sub -bass, and more is better. The low damping factor of low feedback or SE tube amps gives a boomy , inarticulate bass that impress's the beginner. If they use subs they tune them into the >50Hz region to add even more bass boom into the mix.
Eventually it wears a bit thin (and it is despite the boom) , and 2-3 thousand hours later they discover "beautiful" music, or at least their interpretation of what it is.
They decide that this is how all music should sound , how all equipment should sound, and death to all who dont hear it the way they do.
The midrange becomes very important, and female vocals have to have a richness and warmth that is euphonic and pleasant.
Very subjective based, and many get to this stage and stay there permanentely, which is good for them, unfortunately many turn into fundamentalists who don't like to see evolution continue , and will turn to the forums to preach their gospel.
Fortunately many do come to realize that it is all subjective, that everyone hears differently, in different environments, and that their is no "best".
But this doesn't stop them from seeking and this is the dangerous and expensive era for the audiophile, with a new piece of equipment every other month.
Eventually this also becomes a bit tiring and our poor audiophile wonders whats next?
He/She reads the forums and sees a zillion opinions about why this class A amp is better than this class D amp, why flac files sound inferior to wav files, why Sabre dac chips sound better or inferior to 30 year old NOS dac chips.
Again, every opinion is subjective, every opinion is just one persons interpretation, what is the truth?
Unfortunately, in this game it is impossible to completely remove subjectivity from objectivity, just as you cannot declare a glass of wine or a painting better than another, it always comes down to it being simply opinion, it may become a consensus, or acknowledged as the rule, but it will always be open to dissent.
However, up towards the 10,000 hour mark, something clicks and they realize they are listening to a RECORDING, its just a recording of the musical event, its not the actual event itself, but a reproduction of the music played at that point of time, which includes the sound of the equipment used to record it, the ability of the recording engineers to reproduce it as accurately as possible , and the ability of the mastering engineer to accurately transfer the recording to the medium you will ultimately use in your equipment.
You can never hear the original and actual music, the best you can hope for is an ACCURATE reproduction of the music. If you dont like an accurate reproduction and want to use equipment that is "warmer", then the music you listen to in your home is your interpretation of the event, it is less accurate. You are in the land of subjectivity, and while you will hear things as you like them to be heard, you will never hear recordings at their very best (and worst) .
Objectivity and accuracy go hand in hand, the very finest and the very worst are recognised by accurate ears, accurate equipment , and most important of all an honest and open mind that can differentiate what a recording actually is, and can hear it as the recording, not as an interpretation that suits your ideal.
The truth, or at best a near truth, is the highest level of hi-fidelity.
It is no coincidence that at the upper echelons of hi-fi gear , accuracy is the key distinguishing factor, realism can only come from accuracy.
Without fail, all the 10,000 hours+ audiophiles I've met desire accurate recordings and equipment, they've heard all the various flavours of equipment, recognise it as colouration and have the ability to filter or adapt to these colourations in order to hear the recording as it is. Although they may own coloured equipment and systems they strive for accurate equipment above all else.
They can enjoy the sound of a SE tube amp into a high efficiency speaker but know that it is far from accurate . They can listen to to the very latest high technology dac chip , and appreciate that the resolution of it will show up most recordings as less than ideal.
But when a musical event is played with true passion and ability and the recording is faithfully transferred to your accurate equipment, then the true beauty of the performance is revealed, and you are closer to the event."
Posted by
Supratek at
11:03 AM
Mick Maloney is the man behind Supratek Amplifiers. Supratek is a small concern based in Margaret River, WA and exports all over the world. It is fair to say that Supratek punches above its weight - there are very few owners (there are only so many that Mick can hand-build, so there are only so many he can sell). Supratek does not advertise. There is no dealer network. The asking price is not low. Despite all these normally fatal obstacles, the company has grown from nothing to exporting all over the world. The growth seems to be solely due to word of mouth recommendation, which is testament to the quality of the product.
