So today, I dusted off my old PS Audio Power Plant P300 and brought it to work. Wanted to use it with the DAC (and USB S/PDIF converter) as I had always done to extract a bit more quality out of those digital bits. By accident and without me knowing, the person helping also plugged in the Mark Levinson 532H amp into it.
I sit back, do my usual test of dialing up the frequency from 60 Hz to 75 and one more, I hear an improvement. The bass becomes tighter and the sound generally becomes warmer. And as before, increasing the frequency way past that decreases fidelity. Don't ask me why the improvement occurs because the efficiency of transformer actually goes down with increased frequency. Maybe the output caps/regulator work better until the transformer really gets inefficient.
Anyway, I bring a couple of other people and semi-sighted ask them if they hear anything and they both comment exactly as I did. Feeling good, now I turn up the volume and start to see the overload light blinking. I put meter in power consumption mode and I see it going way up as I increase the volume. So ask the guy who helped me to make sure he had not plugged in the amp and he said he had.
So we unplug the amp and run the test again. To my disappointment and surprise, almost all the improvement vanishes! We plug the amp back in and the improvement comes back (OK, this could be expectation bias but let's leave that to another thread ).
Now I don't know if this is due to having common single point power, or that power regeneration does help the big beast. So we are going to call and find out about a bigger unit to test.
Do people use these boxes still? If so, what are your favorite brands and models?
