Originally Posted by tomelex
RR stuff sounds a little extra sweet to me, he does indeed have some harmonic processors (i think tubes) that helps put a "sheen" on the sound....Wrong. You know it is this type of speculation that both you and Tim do that galls the rest here. You can quite easily research how KOJ records since he's been frequently interviewed about his work. And for the record, if you think RR are sweet, then there's really something wrong with your system. If anything, they have the "California" sound and are on the lean side. But of course, I assume you're listening to the CD. You should educate yourself and hear the 15 ips tape.
not saying its bad, but there is a definite signature to RR, no matter what instruments play. Is it your system or ears Tom?
Myles, whats up with all this rhetoric. I said how RR sounds to me. What I hear is not wrong dude. You are way off base.
Yes, it is my system(s) and my ears.
So, RR recordings have a "sound" to me. Are you saying that if all other recordings I play and hear do not "sound" like RR then they are all wrong....geeezzz.
Also, no, I dont have a 15ips tape deck. I never will until they start taping true binaural, then, that will be something worth getting as that sound is hugely more realistic than two channel stereo. Two channel stereo, even at 15ips perfection, is not replication of the live event given two speakers. I got over stereos limitations a long long time ago. Seems a lot of others can not.
And, I have no problem you grouping me in with Tim. We all have things to contribute, and I am technically interested in this hobby by my background in electronics. I like to know how things work and audio is not a mystery to me and it is not magic.
Tom
