I had the DM monos for review many years ago. Cool looking tubesHave you seen Kronzilla monos in person?
I would consider the KR va680 though. Apparently, it is a 10 watt more powerful SX but supposed be significantly better sounding. Never heard it myself though.Yes, I think for the 95db or so speaker the more powerful SX would work better.
The Kronzilla SD and SX are stereo ampsHave you seen Kronzilla monos in person?
I never got the SET thing , i never owned a lamm, so who knows.
What i do believe is that in the right speaker amp match tubes are a faster amplyfing device .
From all the SS i ve owned id say the main factor is is that they are slower.
Doesn't always is a bad thing on certain music it may sound more real then tubes due to is relaxter vibe
Thats why i wanna try the lamm 18 watts set at one time , or the ML 3 s and make Micro happy ( if he hasnt already sold themby then).
I ve owned a very good 300 B for a couple of years ,the Zanden 7000 .
Convergent JL 2 sign is faster , faster is determined in a large part by the power supply not so much the tubes imo.
And its heard to be convergent in that area , ive never seen a tube amp with that big a powersupply / powerbank.
Instant power means instant dynamics.
It won’t likely sound better than a well designed SET on such a speaker.I still dont understand your point , why would one not put the CAT on a 100 dB horn ?
If its quit enough , i dont see a reason why it would not sound good .
I ve heard a lot of those low powered flea amps before , at shows/ dealers i never was impressed.
May be you have a different expirience after all those private( tuned )systems you have heard
I haven't; just in photos. I'm interested in the SX which is a stereo amp.Have you seen Kronzilla monos in person?
Thanks as always; that's good to know. Better transformers I suppose(?)I would consider the KR va680 though. Apparently, it is a 10 watt more powerful SX but supposed be significantly better sounding. Never heard it myself though.
https://positive-feedback.com/Issue67/kronzilla.htmThanks as always; that's good to know. Better transformers I suppose(?)
Didn't know they made a SET.Guys put into equation also Tobian soundsystems KA100 PSET power amps...freakin awesome..made with 300b, 242, 46,,depends on your preference of tube sound signiture
Never liked their speakers that much...Guys put into equation also Tobian soundsystems KA100 PSET power amps...freakin awesome..made with 300b, 242, 46,,depends on your preference of tube sound signiture
Quite possibly...google it as there were some reviews.Thanks as always; that's good to know. Better transformers I suppose(?)
https://tobian-soundsystems.com/en/products/monaural-power-amplifier/MA100Didn't know they made a SET.
