“We argue for example that vinyl and tubes are best bet not perfect.”
Mostly, it is people that sell various solutions who choose not to “see” the strengths and weaknesses of each approach.
Want to know / hear ONE BIG “invisible reason” records and in some cases tubes can sound different?
Put on a record that isn’t your favorite and play it at a decent volume and notice where your gain or volume knob is.
Now, tune the volume down and between songs or in the lead-out groove, tune the turntable OFF.
With the needle on the record but no rotation, turn the gain back up to the same point you had been listening at.
Carefully / cautiously tap on things near / around the turn table and room.
While SS electronics is essentially free of any vibration sensitivity (making special feet Jewlery) the turn table is anywhere from highly to pretty sensitive.
In the old days, they called un-intended pickup like this as something being “microphonic” because it is a microphone.
What happens when you play a record, especially loudly?
If you have a stereo in another room, you can do something else too.
Take two long speaker cables and bring one speaker into the other room.
Take a speaker from stereo two and place it in the room with stereo one.
Now, with the record player in same the “microphone” position (playing a record), play music through the speaker from stereo 2. Now, the sound from stereo 2 is picked up by the turntable / cartridge and reproduced through stereo 1.
If you try this, you will probably NEVER transcribe your records to computer under anything but a quiet background (monitor with headphones).
Records and tubes can have a magical sound, but remember they are ALSO to varying degrees an open microphone in your room and what they pick up that way (room sound) is part of what goes back to the speakers. With a subwoofer and enough gain, one can easily produce acoustic feedback (usually down low) indicating full regeneration of the signal (but like a squealing mic, the sound character begins to change well below outright feedback).
Best,
Tom Danley
Danley Sound Labs
