Isn't it V=IR ?
..yep in the land down under and here as well at least the last time I checked
Isn't it V=IR ?
Ultra sonics and lowering of sperm count. Quid pro quo.perhaps this a good PM topic on what kind of power amps are in that radar, just a suggestion unless you want to talk about the audiblily of Ghz radar amps when pulsed...![]()
Again the issue lots of sweeping statements and generalization and yet we have no idea of the equipment being used nor frame of reference to draw a conclusion, nor the situation. As I have said repeatedly, speakers are only as good as what's in front of them. Feed a good speaker crap and that's exactly what you'll get. In fact, one would be really surprised how much of the issues begin with the front-end. Again, that definition of insanity.
Also, how did we get from ringing to colorations?
Not about audio fidelity. Allow me to introduce you to the null test:
AES Audio Myths - The Null Test
If there really was some aspect of audio fidelity that wasn't known, it would have been revealed 50+ years ago in a null test.
--Ethan
I suppose I brought up colorations. At least for my post you know the speakers, and the equipment by model number. Specific enough?
You have the audiophile idea of transparency that a device can pass on the signal without altering or coloring it. The Spectral transparently passed on the sound of the tube amp. The tube amp couldn't pass on the sound of the Spectral because it wasn't transparent. Simple enough even a PhD might understand, unless he doesn't wish to do so. Again, good SS amps are more accurate nothing wrong with saying you prefer tube sound, just don't present it as superior rather than your preference.
And everything you put in the signal path to achieve unity gain had a benign effect? Sorry I don't buy that for one, much less a microsecond.
As far as the equipment, I seemed to have missed that. Could you provide the post number?
NWould be nice if some audio publication such as yours did an article about such things. I have suggested before that someone with a love for SET's but power hungry speakers could use the procedure to feed an SET which fed a good SS amp to have their cake and eat it too. Do you think the audiophile public would be interested in such a thing?
Without reading the entire thread, can someone summarise why, other than the known, measurable differences, valve and SS amps sound different ?
Thanks
I think known measurable differences are enough explanation. Most valve amps depart from high fidelity to the input signal enough they have an audible sound quality that overlays the input. Is that the kind of explanation you are looking for?
In a perfect amp, output would equal input only with more voltage and current. Tube amps depart from that enough to be heard.
I think DonH summed it up pretty well in his post. Other people have surmised that there is a difference between electrons flowing through a vacuum and electrons moving through a semiconductor. Also, the majority of tube amps have an output transformer which has a big influence on the quality of the sound. The output impedance of a tube amp is also higher than the output impedance of a SS amp and if the impedance is high enough, it will effect the frequency response in non-linear ways. Some of the SF tube amps have a very low output impedance and some said they sounded too much like SS. The McIntosh MC-275 tube amp has measurements that rival a good SS amp.
Surely all those things are measurable?
And apparently enough to fool you into thinking that your VTL tube amps were much better sounding (1/3 better by your estimation) than your Spectral amp until you rigged up your test.
The measurements of the SF amps and the McIntosh MC-275 have been well documented in Stereophile. I trust JA when he makes measurements. As for the sound differences (if any) between a vacuum tube where the electrons are flowing in a stream/beam in a vacuum vice moving through a semiconductor, all bets are off. I don't know if that has ever been attempted and how it would possibly be measured.
