I ended up rupturing the bicep tendon in my right arm.
Weight - it will kill you. I had a magnificent system. 2 strong people per amp. 3 strong people per speaker. GONE. The weight was a killer.
Now tubes & very efficient speakers. Nothing like feather pillows, but better.
Esldude-I think the story you told merits discussion because maybe it sort of gets at the core point I was really trying to make and that was tube amps sound better (to me) from 40Hz up. With regards to the comparison between your VTL amps and your Spectral amp and how much better your VTL amps sounded, your original comment was:
The above comments you made are very powerful if that is what you truly believed before you ran your little test. Some people are spending over 5 figures in order to chase subjective single digit percentage points of improvement in the sound of their system (the law of diminishing returns). Using the subjective WAG system, you calculated that your VTL amps represented a 33 1/3% improvement over the sound of the Spectral. That’s an incredible improvement in sound quality. That’s huge. Monstrous even. All of the audiophile buzzwords that audiophile music lovers crave when they try to improve their systems are what you described for the differences between your VTL amps and your Spectral. More space, 3D effects, smoother, more dynamic, more nuanced, more musical. People are paying serious money trying to create those types of improvements in their system.
And then one day something told you that you to run an experiment. Your conclusion from the experiment was that the VTL was telling you sweet lies and the Spectral was a truth teller that only sounded 2/3 as good as the lying VTL amps. Guess what? If I had an amp (or amps) that sounded 33 1/3 better than my reference amp in the ways that you described and I could afford it, my reference amp would be up on Audiogon waiting for a new home with someone who liked specs better than sound quality.
I don’t know how you have your ears/brain reconcile/rationalize the fact that you left 33 1/3 of the improvements in sound quality you had on the table but somehow now you are happier and enjoying your music more because your experiment told you the Spectral was more accurate. That sounds crazy to me.
And here’s a little clue for you all besides the fact that the Walrus was Paul: electronics that are judged to be “accurate” or “neutral” based on their fantastic specifications whether they are printed or measured can also sound quite boring. And based on the descriptors that you used to describe the differences between the sound of your VTLs and the sound of your Spectral, your Spectral sounds as boring as waiting for customers at a hamburger stand in the middle of a Hindu festival. I’ll take the amps that you judged to be far superior to the Spectral any day and forget the little resistor test.
snippage....and more snippage.
The VTL is one of hundreds of amps; IMO not by any means the most transparent. There is a baby with the bath problem with your argument.
How did you load each amp? Did you do it to idealize either one? You make no mention of the load resistance but its pretty important- otherwise you may not have done this in a scientific manner.
The ironic thing is that I started this thread and the only tubes that I currently own that are in my system is my pair of Ampex 350s. I swore off tubes and sold all of my tube gear except for my Ampex 350s. While my Krell KSA-250 was making round trips back to the factory, I did buy an ARC VS115 tube amp to tide me over and I know exactly how long that has been since it was in my system. And that is due to the fact that when I shipped the ARC to its new owner after my KSA-250 came back, I ended up rupturing the bicep tendon in my right arm. That happened in September of 2013. Two weeks ago, a pair of tube amps and a tube preamp showed up on my door for review. So basically this was the first time I have had tube amps back in my system for 16 months. I'm not letting the cat out of the bag yet with regards to what amps I'm listening to, but I would be lying if I said they didn't have me rethinking owning tube amps again.
Not MEP, but David Manley, he did not believe in them, per his book.
I believe much of what Valkyrie said is pretty much what is happening. Rather than being dead wrong he appears to be right on to me.
OTL's are colored too. And they have a different sound than transformer coupled push-pulls in my experience. Nor have I heard SS amps that retrieve the same kind of bloomy spatial information push-pulls have. OTL's I have heard sound almost smoky on difficult loads and rather quick on loads within their capability, but still not like solid state or conventional tube amps.
I owned a couple C-J's myself, and upon getting a VTL it seemed just clearly better. Mainly I surmise due to the heftier PS and better made transformers.
The bottom line is good SS seems accurate and transparent. Doesn't keep tubes from sounding more beautiful.
Yes, I started to mention Lamm. His idea is the distortion needs to be the same at all frequencies at a given power level. That the distortion needs to increase with power level gently, but steadily the last 20 db or so, and should top out around 2-3% at the highest power to be used. And the distortion should be lower harmonics only. Such in his opinion gives you the most enhanced euphony. His amps have a sound, one he creates intentionally, and one that isn't from transparency, but pleasing in spite of those departures from a theoretical perfect amp.
And yes, tubeophiles almost immediately take umbrage at that. They need not. Stereo is an illusion and craftily done amplifiers that enhance your illusion and enjoyment are nothing to be ashamed of in fact. If that were more readily acknowledged more might be done to get the optimum transfer characteristic. One could even create it with appropriate DSP using transistors all the way.
I would say well done tube amps are quite reliable other than the tubes themselves. In a good design one faulting won't take out other parts.
Funny. When perceptual coding is talked about in digital, it's great. When the same principles are applied to analog devices like amps and preamps as well as loudspeakers now they aren't? It's a weird world man.
It's very different. "Perceptual coding" in digital is controllable, adaptable, reversible. It can, and most often is, used to correct effects that have taken the sound at the listener's ears further from reproduction of the recording. A deliberate alteration of the input, built into an amplifier which offers no ability to bi-pass or adjust that distortion, is exactly the opposite, in both intent and result.
Tim
I nor my acquaintances thought the Spectral was even a serious competitor to the VTL. It however wasn't boring, it wasn't dead, you are letting your stereotypes of SS clinical sound lead you to a wrong conclusion.
As briefly as I can, and I'll touch on the major points, as I'm waiting for a customer to arrive...
1. a good amplifier should not have a 'sound' --it should be a straight wire with gain. No particular signature, neutral.
2. vacuum tube sounds different for the following reasons, and depends also on speaker type:
a: Much lower damping factor. The back EMF isn't shunted by the amp's source impedance nearly to the degree that a SS amp will shunt. Bass reflex speakers will sound 'fattier' on vacuum tube amp than SS.
b: Back EMF generated by coasting voice coil isn't shunted, and, in the case of feedback network in the amp, this EMF voltage gets injected into the feedback network and reamplified a few microseconds later.
c. most vacuum tube amps are transformer coupled. Most modern transformers have fairly high distortion and limited bandwidth. With exception of a few transformer made from 1955 to 1966, most every 'boutique' transformer I've tested has been rather poor, not only at the low frequency extreme, but at high frequencies, more surprisingly. Take an old Peerless model 16432 output transformer, which goes from 37Hz to 40KHz at near full power, and far beyond those limits at reduced power, and compare it to transformers wound today and it's a different world. The art of transformer winding has been lost with the collective knowledge of UTC, Thordarson, etc.
Note: bass reflex is more dependent on amplifier electrical damping, as it lacks mechanical damping at resonance and at frequencies below the tuning frequency.
Back EMF is the electrical current generated by the coasting cone/voice coil in the magnetic field. It is an electric generator during this return to resting position phase.
That's a few of the major points off the top of my head. Got to run.
I guess my question is: the things that cause valves and SS to sound different seem to be very well understood and measurable. So why do we need to resort to conjecture about sound differences caused by the medium in which electrons flow?
Tom,
Sorry, we went through this some months ago in a debate about measurements - I am not wanting to rewind and start it all again.
Good point. I need a new CD transport, with my old one dying, and I had been considering a used Esoteric P03. There are several reasons why I decided not to go with it, and weight was one of them. The 71 pounds were simply too impractical in every way (it's just a transport, for cryin' out loud).
