Don't forget the Beethoven 9th
audibility of distortion is both harmonic content dependent and SPL dependent...the louder the sound level the less sensitive you become to distortion. Since we are talking about the very loud end then this mitigates the audibility of the distortion. This is one of the interesting things about a no feeddback SET, the lower the level the lower the distortion gets where the audiblity becomes more critical and it increases when the output goes up and also the SPL goes up making it less audible.
(...) as far as peaks, they last a millisecond. and have little if anything to do with sustained listening levels. Bonzo was in the room for (LZ 45rpm box set, Physical Graffiti) 'In My Time Of Dying', and 'LZ1', 'reel 1' 15ips 1/4". that's as loud as I listen, but it's very occasional, mostly with visitors. the ML3's just can't do justice to stuff like that. but it's comfortable listening to that in my room at warp 9, with all the system work I've done. (...)
Ked it would seem you and I are guilty as charged, that was a fun night!
Although while at dinner that night Ked did comment on Americans listening to music louder than most.
Failing to see your point Ked...
Absolutely no need to defend yourself here Mike, at all.
Similar trial my friend did like Mike.
Ha has Wilson Alexandria X2 with pre e phono CH and with Viva New Aurora,a very good SET,zero negative feedback pure class A with around 38 watt
Power is enough and sound is very good of this system,and he has a good but not big room.
Before had also Viva top preamp,but after tried CH L1,sold Viva and bought CH,and CH L1 was a perfect match with Viva.
He tried CH A1 in stereo and bought CH A1 mono,for all of us better than Viva with his speaker,voice seems more natural,bass more controlled and deep,high more open and liquid,seems Viva little roll off VS CH and now he listen that in many recording Viva power was not enough and has now power without limitation
Dunno, but it sounded....WONDERFUL.You were surely clipping the amp based on Stereophile measurements! Those speakers must have the sensitivity of mud...
This is quite interesting. Mike has, debatably, both a SOTA SS amp and a SOTA tube amp. Are you suggesting, and is Mike saying, that they still exhibit characteristics that we describe as either SS or tube sound? I would have thought that at this level, those characteristics would have pretty much merged or disappeared, with both amps sounding more or less similar and real, within today's technology limits and that differences will continue to diminish over time.
I assume that people agree that top level gear is sounding more and more real/convincing. Over time, does anyone think that the best SS and tube amps will truly converge and sound indistinguishable, or will there always be recognizable characteristics which we call SS or tube sound? Are these differences just intrinsic to the technology/typology?
It seems these differences would remain even if Mike had a speaker with say 110 dB efficiency. The Lamm would be less likely to run out of steam, but it would still do the bass, the holographic/palpable images, continuousness and musical flow better while the Dart still would be better with the detail and soundstage portrayal. These are the flavors or different presentations that Mike wants to switch between. Will we someday have an amp that can do it all, given an easy enough speaker load?
so I try to get a few hours sleep and you guys trash my thread.
with the darts it's rarely over '0' watts continuous, maybe 7-10 watts sustained continuous 'max'. if i'm listening to anything loud, as jazdoc will attest, it's occasional. Saturday night specifically the one tune that we could not portray properly with the ML3's was Pink Floyd's 'Fearless' from the Original Pressing of 'Meddle' which is a 'go to' track jazdoc requested. he likes to hear certain tracks at 'real' level and asks to turn it up.
I don't go to loud concerts, never have, never will....even when i was young. even a loud sports event my fingers (or ear plugs) are in my ears if it gets too loud. and would wager my hearing less screwed up than most here. i know you are just messing with me, but it's a serious subject for me. maybe excepting Audiocrack, i have more invested in my hearing than anyone, and never take it for granted. i'd also guess my ambient noise and system noise floor level is the lowest of anyone, which allows me to listen at lower levels.
and i continually talk about how significant the first watt is to any listening. if that's not great, nothing that follows can be either.
Thanks for the clarification, Mike...I just remembered you quoting a number somewhat north of 200 watts...what you say for continuous and "max continuous" makes a lot of sense to me.
Brad, I've owned a half dozen SETs and had another half dozen in my system.
spraying loads of 2nd harmonic at high powers may be pleasing to you, but its not right and certainly not SOTA. I encourage you to borrow a First Watt and hear just when your systems start distorting- I'm pretty sure it will surprise you. On my 101db speakers, the 10 watt SIT2 didn't last 93dbs in my largish room.
my own 92db speakers with a very flat 8 ohms are getting 15 watt RMS peaks easily from my Ref75SE and have hit 30dbs on very high dynamic stuff (ie. Sheffield) at higher volume levels. So when I hear you saying SETs on Thiels is cool, I beg to disagree. Also, I've recently heard Maggie 3.7s and run a consistent 60 watts per channel on McIntosh 601s whereas you have suggested folks run SETs on them too. I honestly don't get it.
Anyways, that's all I'm going to say on Mike's thread - because honestly I'm more interested in reading his thoughts in his listening room vs. someone's predilections from half way across the world.
No -- simply and solely for the reason that I have not heard them in a non-show situation, let alone a leisurely situation. If I were to hear them in a leisurely situation I might find them to be the best loudspeakers I have ever heard.
(In my analytical preference framework you know that I believe that one's musical preference is a high-correlation driver of loudspeaker preference. Since my primary musical preference is not jazz it is very unlikely I would prefer the systems you mention over the systems I mentioned. If I listened primarily to jazz I think it is extremely likely I would have gotten a Cessaro Gamma II system or the Viva Masterhorn system, and never look back.)
The KR sounds ear bleeding on the Acoustats. It gets bright, there is no Midbass, and no stage or depth or ease or flow. Both acoustics guru and I were disappointed. The Phoenix on the other hand was so much better on the same speakers in the same room. Not sure what you far with SETs on stats or on apogees but that is a waste of good speakers and good amps. I bet if you were Indian you would have been adamant about putting masala on sushi, you seem to have the same recipe for every dish
In the pantheon of audio beliefs, promoted by audio critics selling high ticket items, one that I find peculiar is that you can "hear" higher power amplifiers sounding better than lower power amplifiers with the same topology when both operate within a power envelope that does not clip or distort either.
I have found the opposite, especially with SS amps, that when operating within the power envelope on reasonably efficient speakers that the lower power SS amps using fewer output devices sound better. I don't think I have ever heard a behemoth SS amp that I liked much, except perhaps the Nelson Pass unobtanium VFET beast based on Sony vintage VFETs at shows.
I suppose if you believe that you can hear the power even if your peak program material is modest, I suppose you can, because you can't enjoy the system otherwise.
It seems that this would be a reasonable double blind type study, but I have never heard of one being attempted.
This guy says his Rigoletto sounds glorious with SS http://theartofsound.net/forum/showthread.php?49866-For-sale-Odeon-Rigoletto-horn-loaded-speakers
