Nope.
Ok, so how do you explain the fact that the ML3's are apparently running out of steam...providing 32watts/ch ( plus headroom) to just the tweet/mid panels of the MM7's??
Nope.
Ok, so how do you explain the fact that the ML3's are apparently running out of steam...providing 32watts/ch ( plus headroom) to just the tweet/mid panels of the MM7's??![]()
and it's not a 'mid-tweet' panel, the 7 foot tall, 750 pound, passive main towers of the MM7's are flat to around 40hz. that's mid bass borderline deep bass.
In the pantheon of audio beliefs, promoted by audio critics selling high ticket items, one that I find peculiar is that you can "hear" higher power amplifiers sounding better than lower power amplifiers with the same topology when both operate within a power envelope that does not clip or distort either.
I have found the opposite, especially with SS amps, that when operating within the power envelope on reasonably efficient speakers that the lower power SS amps using fewer output devices sound better. I don't think I have ever heard a behemoth SS amp that I liked much, except perhaps the Nelson Pass unobtanium VFET beast based on Sony vintage VFETs at shows.
I suppose if you believe that you can hear the power even if your peak program material is modest, I suppose you can, because you can't enjoy the system otherwise.
It seems that this would be a reasonable double blind type study, but I have never heard of one being attempted.
That the Lamm ML3 can even drive these main towers in a large room seems pretty amazing.
Hmmm. I thought the conventional wisdom was that, holding circuit topology and power output (SPL) constant, the lower power amplifier would tend to sound better than its scaled up, higher power version.
For example, if you play the Jadis JA-80 and the JA-200 at the same power output, the JA-80 would sound slightly better than the JA-200? Am I wrong about this being the conventional wisdom?
DING, DING, DING, DING! RogerD and morricab back to your corners!
We should all be past this basic fencing. Not every post needs to start with the Big Bang.
RogerD, why are you having so much trouble accepting the fact that some people prefer the sound of tube amplifiers?
morricab, why are you having so much trouble accepting the fact that some people prefer the sound of solid-state amplifiers?
Why don't one of you please start a whole new thread on this subject, and let Mike get back to the subject of his opening post?
I'd like to know what the real measured impedance of the MM7's are. If you look at measurements in Stereophile, impedance loads of the speakers are always measured much lower than that the manufacturer states as the nominal impedance. It's impedance that really matters here.
compared to not running out of steam in other 'non-horn' systems?
and it's not a 'mid-tweet' panel, the 7 foot tall, 750 pound, passive main towers of the MM7's are flat to around 40hz. that's mid bass borderline deep bass. and as I've said a number of times and you have ignored a number of times, the ML3's are more dynamically alive in my system than my recollection of Steve's system, which you feel is dynamically just fine. which takes us back to the difference in our references as to what is not running out of steam being the issue. i simply have higher expectations than you do. when i feel the ML3's face recordings where they fall short, it's in direct comparison to my reference with the big darts. nothing to be ashamed of there, no other SET could compete either.
do we need to circle around this same issue a third (or is it the fourth) time? as i said before, your references for ease and authority on large scale music need some work. maybe we should only discuss issues when we are both listening to the same thing together......so we can get past this semantics and reference issue.
come on up to my room and hear what i mean by ease and authority on large scale music. or realize that we view Steve's ML3 room (which is fine and i liked) through different reference perspectives.
Jeff, I’ve never seen MM3 measurements but the diminutive MicroOnes have been reviewed with extremely flat phase graphs. Presumably both use low order cross overs
A quick search showed that Evolution Acoustics states that the MicroOnes are 6 Ohms. The Hi-Fi Plus review has measurements that shows the impedance dips to, but not below 4 Ohms at 200 hz. The impedance is below 6 ohms from 100hz though 4K. So, like most speaker manufacturers, you have to take the impedance specs with a big grain of salt.
What am I missing here....I own a VAC 70/70 and a pair of 140's but my high powered SS amps are better....what can I say. They do everything the VAC's can and more. I just have different experiences then everybody else albeit my amplifiers are extremely rare...if I'm out of line here...just say the word and I'll bow out but I don't believe my opinions have been problematic.
