Zanden Aiudio Chouku - new statement mono amp from Zanden Audio
LL , you are welcome ...more for you ....
Thanks, Jazzhead!!!
So Keith, the midrange is the same, just the bass differs?
I think the Zanden Chouku will eat Lamm L3 for Lunch.
Was the Chouku even manufactured?
It doesn't show as a product on the Zanden website
http://www.whatsbestforum.com/showt...m-Zanden-Audio&p=207617&viewfull=1#post207617
At least the Lamm ML3 is a real product rather than a one off
This very special Zanden amp can only be ordered though Audio Exotics; however, as far as I know it has not been a one off. Pretty sure though that mister Yamada has non of these huge WE tubes available anymore. So I presume they can only be delivered with newly made tubes which are likely not as good as the ones produced by WE in the past.
Yes it does exist. I helped move one recently. It is the heaviest amp i have ever tried to move. My car suspension almost broke.o_O
Isnt it like 500lbs per channel? That is rivaling the D'Agostino Relentless which is 570lbs.
Exactly. But you would never think so from its looks. And its not easy to handle like a typical flat amplifier.
