1) the Network and XDMI cards move from your Olympus to the I/O
2) those are replaced with 2 interface cards which connect to the I/O over 2 QFSP cables
The 2 interface cards as well as the 2 QFSP cables are supplied with the I/O.
I would venture to say the Olympus and I/O are actually a surprisingly good deal when you consider how clean and clear the analog out card sounds. I'll have more to follow once I have both my Cascade and the analog out fully broken in (currently a few hundred hours on each). From what I heard before installing my Cascade, I would suggest starting analog out in your system and then demo your DAC against that sound (after break-in for each version). Impressive job on that Taiko.
And I understand an even better internal DAC is in the works.
FWIW [Olympus + I/O internal DAC] easily sounded better in my system than [Extreme + Select2]
Not asking for you to give away any secrets but is there an evolution path for the I/O? That is, are there any advantages of splitting up the network card and DAC into separate boxes? Or some other future design?
Re tariffs, it will be fluid, in that a tariff could shortly go away if an agreement is reached. It will also be helpful to know how broadly goods are classified for determinations of reciprocity. Lastly, I'm wondering how soon Taiko would consider sending components to Vassil at cost for final assembly in the US (anodizing?).
For clarity, we’ve been considering manufacturing servers in the US for years, which just became much more attractive with @nenon onboard. This would not be a (temporary) move to (temporary) circumvent (temporary) tariffs
The I/O system has been designed for maximum flexibility. You could indeed use 2 I/Os to split up the network card and DAC into separate boxes, however that would currently not provide you with any significant benefits. But yes we could get creative and in theory have separate I (input) and Os (output) in the future.
You could go more Extreme with future DAC versions as well of course, in theory you can go dual mono, split digital and analogue, you'd have 2 I/Os then with 4 separate battery supplies for left/right digital and analog.
The I/O system has indeed been designed for maximum flexibility. You could indeed use 2 I/Os to split up the network card and DAC into separate boxes, however that would currently not provide you with any significant benefits. But yes we could get creative and in theory have separate I (input) and Os (output) in the future.
Has the previously mentioned analog out volume control proven to be viable? Would it work in the current I/O chassis? Would it work in the current Olympus chassis? Thanks.
We're indeed working on an improved version with both balanced as single ended outputs. Possibly more modular / split digital/analog sections for even more flexibility.
There will be (free) software updates which improve performance as well.
We have 4 different ways to implement volume control, 3 in software (digital), 1 in hardware (analog). All 4 would work in both the Olympus and I/O chassis.
No shortage of permutations to consider when contemplating this Dutch Army Knife. Now that the clock has started for placing orders prior to the April 7 price increase, understanding the possibilities with this added chassis is key to financial justification for some. Any feedback from Taiko is worthwhile. Thanks.
As far as I can tell, it appears that the EU tariffs of 20% on products exported to the United States will apply to all upcoming Taiko shipments to the US because tariff liability is generally determined by the date of importation, not the date of purchase order or payment. If that is not correct, I would love to hear about it. I am not clear on what value would be assigned to an Olympus server, for purposes of levying the 20% tariff. In any event, this is all very unfortunate for those of us, like me, who ordered an Olympus (and/or I/O) in December 2023 or very early 2024 and are projected to receive the gear later this year. When my Olympus is ready to be assembled, I will be in touch with Taiko to explore these issues.
