Good morning WBF!​
Re tariffs, it will be fluid, in that a tariff could shortly go away if an agreement is reached. It will also be helpful to know how broadly goods are classified for determinations of reciprocity. Lastly, I'm wondering how soon Taiko would consider sending components to Vassil at cost for final assembly in the US (anodizing?).
Reactions: audio42
Yes about equal.
In my experience, the analog out of the Olympus is just excellent. It has all I wanted like speed, resolution, lots of space and layering, tonality, harmonics, no digital harshness, dynamic.
Mind you, I nevertheless still like to listen to vinyl which, in my case, still betters my digital solution though the margin has shrunk quite a bit.
When hearing there would be a built-in DAC in the Olympus, I did not hesitate a moment to order the Olympus and to sell my DAC at the same time.
Didn't regret it one second.
Thanks to team Taiko!
May I ask what your former DAC was? I ask as I have not ruled anything out. I'm keeping an open mind and will let my ears be the final judge...
@John T , @flyer does not have an I/O, not claiming that that would change his preference for vinyl over digital at all, just adding this for clarity since the answer to your question about adding an I/O was quoted :)
And @flyer thanks for the feedback, happy you’re enjoying your Olympus!
To add a I/O to the Olympus is it just a matter of moving and installing cards between the units or is there programming as well?
Moving cards only.
1) the Network and XDMI cards move from your Olympus to the I/O
2) those are replaced with 2 interface cards which connect to the I/O over 2 QFSP cables
The 2 interface cards as well as the 2 QFSP cables are supplied with the I/O.
Reactions: Kingsrule
I would venture to say the Olympus and I/O are actually a surprisingly good deal when you consider how clean and clear the analog out card sounds. I'll have more to follow once I have both my Cascade and the analog out fully broken in (currently a few hundred hours on each). From what I heard before installing my Cascade, I would suggest starting analog out in your system and then demo your DAC against that sound (after break-in for each version). Impressive job on that Taiko.
And I understand an even better internal DAC is in the works.
FWIW [Olympus + I/O internal DAC] easily sounded better in my system than [Extreme + Select2]
Not asking for you to give away any secrets but is there an evolution path for the I/O? That is, are there any advantages of splitting up the network card and DAC into separate boxes? Or some other future design?
For clarity, we’ve been considering manufacturing servers in the US for years, which just became much more attractive with @nenon onboard. This would not be a (temporary) move to (temporary) circumvent (temporary) tariffs :)
The Cascade with BDT is just amazing..did u have the BDT installed yet?
The I/O system has been designed for maximum flexibility. You could indeed use 2 I/Os to split up the network card and DAC into separate boxes, however that would currently not provide you with any significant benefits. But yes we could get creative and in theory have separate I (input) and Os (output) in the future.
You could go more Extreme with future DAC versions as well of course, in theory you can go dual mono, split digital and analogue, you'd have 2 I/Os then with 4 separate battery supplies for left/right digital and analog.
The I/O system has indeed been designed for maximum flexibility. You could indeed use 2 I/Os to split up the network card and DAC into separate boxes, however that would currently not provide you with any significant benefits. But yes we could get creative and in theory have separate I (input) and Os (output) in the future.
Has the previously mentioned analog out volume control proven to be viable? Would it work in the current I/O chassis? Would it work in the current Olympus chassis? Thanks.
We're indeed working on an improved version with both balanced as single ended outputs. Possibly more modular / split digital/analog sections for even more flexibility.
There will be (free) software updates which improve performance as well.
Hopefully also at least two digital inputs, even if optional.
No shortage of permutations to consider when contemplating this Dutch Army Knife. Now that the clock has started for placing orders prior to the April 7 price increase, understanding the possibilities with this added chassis is key to financial justification for some. Any feedback from Taiko is worthwhile. Thanks.
