Thanks for your input. I come from a technical background, so allow me to shed some light.sbo6, I know that it may be difficult to believe, but over the years I have collected a tremendous number of bass blasts in my music collection, and I appreciate your comment, but take the M9 for example. I would take a bet that the XVX would easily, and I mean easily best it as far as overload resistance. I don't understand why, but it is extremely impervious to overload. On heavy bass, I mean really heavy bass, the woofers hardly even move, even when you are a foot away trying to see at least a little movement. This is simply a fact. I asked Robert Harley if he had ever seen his woofers move (excursion) and the answer was no. I can't speak for other massive speakers and nothing is impossible, in the real world, with any kind of bass blast or extremely heavy low frequency transient, the XVX is essentially indestructible, 100%. I don't think it has much to do with the size of the woofers or the surrounds. The woofers simply have almost zero excursion for all intents and purposes. Perhaps someone might have an explanation. I can attest that without the Thor the XVX will produce amazing bass. There's nothing malfunctioning.
This is why you can run it full range. There is no subwoofer including two Thors, that can keep up with an XVX. You can have any subs you like, run the XVX full range, and never worry about overload. The subwoofer will go long before the XVX.
It doesn't matter whether the drivers are from Wilson, Magico or any other company, they're all subject to the same laws of physics. Those laws specific to drivers and in particular, bass drivers output include Fmax (excursion capability) and cone size as key enablers to bass output (of course motor structure, cabinet size / design, XO matter too). If you want to see your XVX woofers physically move, run a ~25Hz test tone at ~90DB. That moderately - sized 10" woofer in particular should be visibly oscillating even if it's below the port tuned frequency. If it's not, then there's an inefficiency in the motor structure and / or the crossover or a limitation in the design. Again, it's physics which doesn't care about one's fondness for a brand of loudspeaker.
Also, (again with physics, not a brand bias in mind) a Magico M9 with twin 15" woofers employing larger motor structures and significantly more cone surface area vs. the XVX, all else being equal will deliver much higher SPL at lower distortion. For reference: the XVX woofers surface area = ~192 sq ", the M9 = 353.4 sq", over 1.5X the Wilson. To put things in perspective on how capable the M9 is in bass versus the Wilson XVX, the M9s mid - bass driver (2x11") are essentially the same surface area of Wilson's woofers. That's before even considering the 2 x 15" woofers. Net - they aren't even in the same league, a better woofer capability comparison would be XVX vs Magico M6 with 3: 10.5" woofers.
I hope this helps provides a more objective and scientific view.
