Munich HES is coming up, and among the few new designs that are having their debut, we will trust our analog reproduction to our wonderful new small phono ,Hermes.
Some data on the new ("entry level" ) phono system:
Cheers
Stavros
See you all in room F111Basic gain structure: 66db
E-sut gain (standard) : 14db (80db total)
Optional sut: X30 (30db) (96db total)
Noise floor: < -70db unweighted , Ref 0db, Max output: >30dbv
Inputs:
1X E-sut (standard),
1X direct input or SUT (optional)
Direct and E-sut input loading : With internal resistor modules. No limit in loading resistance values
RIAA EQ: Discrete LCR system with custom coils
Ouputs: Single Ended, 500 ohm output resistance
Tube compliment: 2x 12AE6 (E-sut)
6~ 10 x 6j11p-e ( RIAA and output stage can work with double or single tubes)
Tube compatibility: Any of the E280F supertube family, E810F, D3A , E180F, 6j11, E282F etc.
External PSU: Solid state rectified for tube stage. Supercapacitor bank/pseudobattery system for E-sut
Dim: 500mm x 490mm X 165mm H
PSU: 190mm X 300mmD X 70mmH 4kg
35kg
Cheers
Stavros
