Need guidance on a Pacific 2
JAHMAN
7
Mpls, MN
I just acquired a Pacific 2, no volume control, built in late 2023, used several months, then traded in for different gear. It has been sitting for a year--I have not tried it yet. Ok to power it up as is? I have no streamer for it--want to use my Esoteric K01-XD SE as a transport to play standard CDs. Using digital out from Esoteric, AES/EBU cable to Pacific input, then analog XLRs out to my preamp. I could use a variac to power up DAC, or does it stage up slowly by design? Thanks for any advice you have.
Dont see why not personally, what tubes have you got?
They supply lots, so more specifically...?
I will be receiving the EML PX4 Mesh DHTs, as recommended by Lampi. Turns out, I was sent some old Philips MRO PT8's that were rolled in to replace what was factory supplied. I did get the KR 5U4G, as originally supplied. I am discovering what I received and what I did not get, but it will work out. Not sure about the Philips I was sent--and does this tube have an adapter? Thanks!
Those EML are potentially very good, be interesting to hear what you think.
No experience on the PT8s, but if Lampi supplied them, I assume they will be fine!
Those PTs are gold man! Super rare and expensive these days, and sound wise also in the tier of best tubes for Pacific.
As for the sound, PTs are more neutral, a bit lighter sounding and more linear than PX4. PX has more slam in the bass region, but in the same time less airy sound. It's up to your ear.
