Good morning WBF!​
That analog out takes hundreds of hours of playing to reach its stride, but I'm incredibly impressed with it. It makes a great case for keeping the DAC work in that same quiet battery fed environment, and with the shortest, most direct XDMI connection, to boot. It's a shame one can't break in multiple cards at once to speed up valid comparisons.
multiple cards , would be excellent option . When I first heard of the IO option my first thought was the option to use atleast a couple cards
Reactions: gds7368
In theory you could use up to three simultaneously, we may need to adjust/add some code to assign different identifiers to multiple XDMI cards — so you and/or Roon knows what’s what.
There are 3 slots suitable for the XDMI interface. When XDMI is mounted inside the Olympus server these are blocked, but 3 I/O interface cards do fit.
You’d need 2 I/Os, 3 XDMI baseboards, the 3 output options you’d like to use, and 3 I/O interface cards. Obviously this will not be cheap.
For quick comparisons / demos I use 2 I/Os and swap QFSP cables.
Disclaimer: This is not a recommendation or an attempt to sell more I/Os. :)
You only need one card, analog out:)
tangentially related:
i've started a thread asking what, if anything, that we've learned from our progress with the highest end digital audio is applicable to improving bluetooth or other wireless headphone sound quality.
Reactions: kennyb123
I am curious what others have found using higher end power cables on the Olympus/IO , if this was already discussed pls point me to that discussion
I had to turn everything off in my system today. All is back on -- except for the Olympus/Roon Server connection. This has happened before and is why I'm always loath to power anything down with Taiko and Roon.
I tried multiple server reboots, router and switch reboot with no success. Is the next step uninstalling Roon? Will that mean I lose my data -- playlist, etc?
It is a connectivity issue, not Roon.
Do you see your Olympus on your Taiko network? And on which network is your tablet?
It sounds like your Olympus isn’t on the network. Either it isn’t booted or there is an issue with the connection with the router or switch.
It’s definitely booted. I’ve pulled connections and re-inserted. All lights that should be on or on.
Much appreciate the help!
I would let things play for a couple days just to make sure they are stable and the connection is consistent. Then I would add the switch back in and see what happens. If you lose connectivity then you have to trace back and see what's causing it. It could be power to the switch, including the cables, or the DAC cables added once you brough the switch back in.
I diddled with the switch cables, reconnected switch and server again and connection returned. This was a good learning experience for the next time (and there will be a next time) this happens!
Another suggestion for people is to have a network app on your mobile device so you can, while on the Taiko network (assuming you have a router), confirm that the Olympus has connectivity. Oftentimes when Roon can't find your Roon core it is because the Olympus isn't "on line."
Wil Do you think it was the DC connection? Often times some of these connections are not as snug as they should be...
Reactions: fizzletop
