Good morning WBF!​
We have several exciting developments in progress. However, as a small team, we must prioritize our efforts and cannot tackle everything simultaneously. By focusing on key decisions now, we can ensure that our future projects receive the attention they deserve, even if some may need to wait a bit longer. Thank you for your understanding!
Yes, of course I understand. You should decide the priorities of your projects. Only if "almost finished" means what I think it means, it seemed strange to leave something unfinished that's so close to completion. We'll wait then.
Awhile back I was mentioning when stacking the Olympus and IO that I would make sure they both sat on a proper shelf/foundation/platform. (As long as you have the space) Several of us were discussing different substrates etc. This is a combination of Baltic Birch, MDF, and 3/8" aluminum. The Birch is what is in contact with the aluminum. This design is for my Monoblock's. Hence the girth and size 29" X 23". I have made a bunch of these for some professional musicians in Nashville. Typically Marshall amps. All have reported It tightens everything up. Stages sometimes have a lot of give. I don't finish the ones I make for them as they beat the snot out of them, just a clear coat. These will be wrapped in a maple veneer. Waiting on a veneer vacuum press. Insanity!! I'm thinking something similar for the Olympus/IO but with a thinner profile, same materials. For the Olympus/IO I could make the platform the same sexy shape, just a little bigger all around. I have a guy with a waterjet who cuts the aluminum. I'm still not sure what footers I would use if I make one for the O/IO, maybe the same ones? I did make a prototype, just square, with the same footers and the Olympus minus the IO did sound better than without it. I'll experiment more with that. I use 6 of the ones in the pic for each platform, along with sorbothane gaskets that I hand cut...
As MarkusBarkus mentions, it's best to use the same phase. Further, to avoid ground loops, it's best to use the same AC ground. Generally speaking, I find that using the same single ground for the entire system yields the best coherence and focus. Conversely, when sourcing ground via different cables and from different spurs, this tends to have a blurring effect. This is not an issue for galvanically isolated devices like Routers, which are frequently located in other rooms and on different circuits. When you have multiple 100% identical spurs, the outcome can differ, and there are other exceptions, as no two situations are alike, so it may be worth experimenting.
Regarding Roon extensions, basically, the more Roon does, the more network traffic it generates, and the more audible its effect. Then again, with Olympus, the Router, Switch, and DCD, we have various measures in place to minimize Roon's influence.
In cases where I disabled Roon volume control for a DAC, this has often been audible, even at 100% volume. However, in such cases, it is hard to determine whether the impact is due to Roon traffic or processes within the DAC. A preamplifier could behave similarly or differently, but neither Emile nor I have a preamp that allows this, so we have no first-hand experience with it.
If or when you decide to test this, I would be interested to hear the results.
I have now done some testing with using Roon with the Home Assistant extension. Unfortunately it does seem like turning on the connection to Home Assistant for convenient volume control does cast a veil on low level signals, I hear it best during quiet orchestral pieces where the ambient information seems a bit less "real".
I will have to confirm this with different pieces of music but I am leaning towards a negative impact.
Reactions: Armsan
