I have two current setups, one livingroom 2-channel and a small tv-room theater setup and am building a five seat larger scale theater.
The speaker brand of choice is almost completely Ino Audio (which is a brand you can only buy new in Stockholm, Sweden - but the sister brand Guru Audio is available in some other countries)
Let's start with the livingroom one:
...note, I don't believe in putting make-up on my photos by cleaning and moving things around to make a pretty picture. The TV looks bad due to kids fingerprints, which you hardly see without the flash. It's a room that is used for kids playing with toys, video games and watching movies as well as listening to music, and then it looks like this...
Music sources:
Sonos via Benchmark DAC 1
Pioneer DV-668AV
Preamp:
In the picture it's a Sentec SC-9, currently there's a Krell Showcase instead.
Active bass module crossover:
Ino Audio cr80s (signature) with added Infrasonic boost plug-in module
Main speaker power amp:
NAD 208 THX
Bass module power amps:
2x NAD 218 THX
Main speakers:
Ino Audio pi60s-s ( Signature - Stone )
Bass modules:
8x LTS B1 made in 1" MDF. Closed cabinets 117 litres each using NHT 1259
For experimental purposes, I've also got a Carver Sonic Hologram Generator hooked on a tape loop to be switched in if wanted. Bought it just for fun to try, it actually worked better than anticipated.
TV-room:
Front speakers (green) Ino Audio piP
Center channel (white) Ino Audio iP (same elements as piP, closed smaller cabinet)
Bass module (purple) Ino Audio profundus-X (one out of four)
Surround (ambience) speakers: 8x Ino Audio a2
One bass module hinted behind the corner same as one surround. There's actually two bass modules stacked there now.
Rear corner bass module
TV:
Pioneer 5090 Kuro
BluRay:
Currently a cheap Philips, Pioneer broken
DVD:
Pioneer DV-668AV
Receiver:
Pioneer LX-73
Amp for bass modules:
Denon POA-2800
Home theater:
...Under construction...
Will feature:
BluRay:
Unknown
DVD:
Pioneer DV-668-AV (Yes, I do have three of those!)
CD-Player:
Pioneer PD-S06
Reciever:
Denon 2807 (to be upgraded at later time), the Krell Showcase is a possibility too.
Ino Audio cr80es (signature extreme) with added Infrasonic boost plug-in module
Main speaker and center speaker amps:
Rotel 1090:s
Bass module amp:
NAD 208
Front and surround speaker amp:
Marantz MM9000
Front speakers:
Ino Audio i32s
Center speaker:
Ino Audio i16s (2-way with same boomer as the 2½way i32s has two)
Surround speakers:
Ino Audio a2 (x8)
+ experiment with ceiling surround channel using Ino Audio a1 (x4)
Bass modules:
Ino Audio infraY-6
For future upgrade to 11.x
Front high:
Carlsson Ortho-acoustic OA-51 upgraded to OA-51 Larsen Edition
Front wide:
Carlsson Ortho-acoustic OA-52.2
Music sources:
Pioneer DV-668AV
Preamp:
NAD 208 THX
2x NAD 218 THX
Main speakers:
Bass modules:
TV-room:
TV:
Pioneer 5090 Kuro
BluRay:
DVD:
Pioneer DV-668AV
Receiver:
Pioneer LX-73
Denon POA-2800
Home theater:
Will feature:
BluRay:
Unknown
DVD:
CD-Player:
Pioneer PD-S06
Reciever:
Rotel 1090:s
Bass module amp:
NAD 208
Marantz MM9000
Front speakers:
Ino Audio i32s
Center speaker:
Surround speakers:
Ino Audio a2 (x8)
Bass modules:
Ino Audio infraY-6
Front high:
Front wide:
