Anyone use the Audio Tools iphone app?
caesar
893
1,698
How good is this app? It's only $20. What are the most pertinent modules for audiophiles? If this thing really works, it could be a killer app for guys setting up your gear.
Also, they are asking $200 for a microphone? Do you have to use theirs?
http://www.studiosixdigital.com/
Can you use this app without another microphone Steve? Another words, just use your Iphone?
yes. The digital mic is fantastic. I threw out my Phonic after getting this one. It gives 1/6 octave RTA as well as spectrograpgh, FFT and test tones
I use the Stereophile Test CD Track 4 with Pink Noise
The digital mic built into the Iphone is fantastic? I have the Iphone 4s.
I have the 4s also Mark
For $15 give it a shot. As I said, I compared it to my Phonic and stopped using my Phonic
I will give it a shot. I'm in Iowa right now for one more week and will be coming home this Friday.
I'd be interested in what you think of it Mark. I've been using it now for the past 2 weeks and am very happy. As I said you'll learn a lot about your room.
I hope it's not hard to use and understand.
Even I could figure it out Mark. You just bought an expensive LP. For $15 buy the app and give it a try
Oh, I'm going to buy it Steve.
I went to download the app, but I have to upgrade to the newest IOs operating system first which I'm doing right now.
I use the StudioSix Digital app, and highly recommend it. It measures fairly close to my larger measurement rigs based around ETF (RD) and REW along with two separate calibrated mics.
So for 'casual' measurements, it's great. And still very applicable if that's your only measurement choice. definitely better than nothing.
You use pink noise Christian just like you would with any RTA. I maintain that at $14.99 it is a terrific app. Christian use track 4 of Stereophile Test CD and learn something about your room response before you so glibly condemn this app. As I said, it is so good that I threw out my $275 Phonic PAA2
I also bought the Onyx app at Steve's suggestion. It has proved extremely useful, especially for the price. I was able to identify a few problem areas in frequency response in my room very quickly.
Lee
I am not condeming it. Just trying to figure out the proper way to use it. Thanks for the tips on how to.
which stereophile test cd are you talking about ? CD1 that has pink noise for test track 4 ?
