List of Potential Cables
NMMark1962
116
Santa Fe, NM
Okay all, I am sure this will stir passions and generate opinions, so here goes..
As I am planning a VERY substantial 2-channel system for late this year, I have a pretty short list of candidates for amps/preamps, front ends and speakers...but cables have the largest numbers due to some of them being very familiar to me and others, brands I really want to try...
Thus, the cables on my list are as follows (and are in no particular order): Tara Labs (The Zero, Omega and Cobalt), Argento Audio (Flow Master Reference), Shunyata (ZiTron Anaconda), Transparent (Opus MM2 and PowerLink MM2 AC), Kubala-Sosna (Elation!) and Purist Audio (25th Anniversary)....another potential line are the Evolution Acoustics cables since I am also going to listen to the MMSeven speaker.
Of all these brands, I can say I am the most familiar with Tara Labs. As far as Argento goes, I had a chance to fill out my system with their former entry level stuff and it was scary good for entry level)...as far as the others go, all I have to rely on are the many positive things I read here and elsewhere on the quality of the cables. I now know that Transparent can create cables for each specific component in one's system. That is enticing but also dreadfully pricey for the Opus MM2 stuff. Also, I was happy to learn that all of these companies can make the honking custom power cords for the large Boulder amps....
So I guess what I would like most of all is feedback on the Kubala Sosna and Purist Audio....and, anything else in regards to the Evolution Acoustics cables.....
MANY thanks
Mark
MANY thanks
Mark
I did own and love the Transparent Opus MM2 speaker cables for 10 years. a fantastic sounding cable. even though expensive it delivers. a few years ago I compared it to the Evolution Acoustics DRSC (double run speaker cable) and liked the DRSC about the same as the Opus MM2 on my (then) Evolution Acoustics MM3's. there were trade-offs. the EA DRSC's were more open and balanced on top, the Opus MM2 was a bit dark on top (at least it was in comparison to the EA cables on the MM3's). I did love the sexiness in the bass of the Opus MM2, but the EA DRSC were a bit more dynamic, energetic and linear in the bass. likely the EA's had some synergy with the speakers. considering what I could sell the Opus MM2's for I did switch.
then a year later EA came out with the TRSC (triple run speaker cable) and I upgraded (and soon thereafter to the MM7's too). it was simply better all around, which was quite impressive. super low noise floor, great micro-dynamics, smooth and extended on top, and a great flow and top to bottom coherence.
on the power cable side of things I use 10 of the Absolute Fidelity power cords from Genesis. and......2 of the EA TRPC's (triple run power cables) for my dart 458 amps. really really good. and if you do happen to get the MM7's, I use some (you need 4) special Absolute Fidelity power cords for subwoofers on the bass tower amps which are excellent.
the only negative on the EA cables is you have to be patient; the cable builder also builds the speakers and he is pretty busy.
I have a friend in Dallas (Albert Porter) with all Purist 25th anniversary cabling. That is literally one of the best systems I've ever heard. I have some Purist and mostly Transparent' s...both my former Wilson Maxx 3's and current Rockport Altairs are internally wired with Transparent...and a lil synergy at work I suspect...The Purist definitely belong on your list.
I do not think you have to go all the way up to Opus to get great Transparent cables...I have a few Ref XL MM2's (din to rca, then 2 rca-rca from SUT to phono stage, then phono to pre). Then Trans Ref MM MM2 from pre to amp and amp to speaker...so my analog is all Transparent.
I find the Shunyata power cords/conditioners to be great...your list might have better options on the signal cables...but i don't have first hand knowledge here...just have 2 friends that did the Shunyata-Transparent comparison. Both had Shunyata power cords. They kept the Transparent signal cables and stuck with Shunyata on power..
In the end...all of this comes down to what you prefer in your system...no hard and fast rules...
Curiously Kimber and Cardas seem to be forgotten in high-end forum recommendations, although IMHO they manufacture excellent cables.
Although we can not correlate technical specifications of cables with sound quality it is important to consider them - some combinations of equipment and classical parameters, such as capacitance, will probably result in poor performance.
Did I miss something? I mean, what's the system you'll be putting these cables on? Have you picked speaker/electronics yet?
alexandre
The High Fidelity Cables from Rick Shultz are up there with the best to much lower prices than some of the ones mentioned here. Not saying that they are better, but these are very good. Good luck.
alexandre
Okay....speakers under scrutiny....Focal Grande Utopia EM, Rockport Arrakis, Evolution Acoustics MMSeven/MMThree, Wilson Alexandria XLF and MBL's 101 eXtreme's...
Amps: unless I hate them when I hear them later this year, the new Boulder 3050 monoblocks and the upcoming 2110 Preamplifier
Digital Front End: dCS Vivaldi
That's about it for now....
Cheers,
Are you referring to Albert's system with the big Dali's or is what you heard with his new Focal Grande Utopia EM's????
MANY thanks,
Any Listening notes on the sonic signature of the 25th or other Purist cables in general ? Thanks
NMMark1962,
If the jury hasn't rendered it's final decision, take a look at MG Audio cables for your ICs & SCs.
MANY thanks,
Hi, well actually both systems. I haven't had a lot of time with his new Focal's...but the Focal's sound killer good, I am trying to get back up there soon for a longer/more careful listen...
For what it's worth, I use Purist 20th Anniversary cables on my power conditioner (a pair). And for the equipment, I normally keep Kubala Elation on the digital (DAC and transport) and Transparent Ref MM2 on the pre+power.
ICs and SC are Kubala Elation as well.
alexandre
That is what I am planning on doing as soon as I can...I hope by this fall his speakers are finished breaking in though I do not know how he breaks his speakers in as people have many ways that they like to use....I send him an e-mail about every two weeks pestering him for updates!!! hehehehe
Cheers,
NMMark1962,
I think they are some of the best cables out there along with Crimson cables from Crimson Electronics. The problem is they don't cost as much as a Porsche.
Exactly.
Why does the market in, say, amplifiers support a price multiplier differential of 500 (or whatever) between "good" and "best" but supports a differential ten times that when it comes to cables? Indeed, not merely "supports" but "demands".
I have been listening and represent Kaplan cables from Brooklyn, New York and I like them a lot. I have the GS Mk.II interconnects and GS Mk.II speaker cables as well as GS Mk.II source and high current power cables. They are very transparent with no veiling and provide a grain-free midrange. I have them if anybody would like to test-drive them for a week or two. Great cable for a very reasonable price.
I have some in for review too :)
Aren't those by Occam? I've heard nothing but good things about his cables from my NY Rave buddies.
