Time to remove the tarnish from those HiFi Tuning Supreme fuses again
ack
May 6, 2010
6,774
1,206
580
Boston, MA
The leads on mine were tarnished to varying degrees. This time I am going to seal with electrical tape...
Did you take any pictures?
yes i've noticed this on some of mine...can't be good...
Noticed the same on mine , how does electrical tape help ?
Here, I missed one
I meant electrical tape around the exposed part of sockets - not the fuses - for atmospheric isolation; it's probably not going to do much...
are the fuse end caps made from pure silver?
With time the directional arrow gets smudged . So orientation while realigning the fuses , does cause some bother
are you referring to their logo which shows the schematic symbol for a diode as being the directional arrow?
Yes. Also, thinking that the fuse element itself might be affected, I went ahead and sealed the gap between the end caps and the ceramic body with glue, and let the glue set for 6 hours.
Who would have thought you had to do routine maintenance on fuses?
high end performance, high end pains :D
Yes .. the diode symbol doubles up as a directional arrow 'hot to neutral or plus to minus' ....
Has anyone confirmed this with the manufacturer that this was their intent with their logo? The schematic symbol for a diode is cathode to anode which means negative to positive and not "plus to minus." You would have to flip the fuse to the opposite direction if you expected that configuration.
Thanks for the clarification , not directly from the manufacturer , more hearsay and stuff on the net . There is however a definite difference in final results , depending on how you align the fuse. Any thoughts on a fuse being directional ?
That's what I thought. Fuses have been around for many, many years and to my knowledge, no manufacturer has ever assigned a polarity direction to their fuses because there is none. Assigning polarity direction to a fuse is something that audiophiles discovered. If you are worried about a 3/4" long piece of wire, how do you know that all of the hook-up wire in your amp and preamp is oriented in the 'correct' polarity?
I do not , and there's nothing I can do about it , this little 3/4" piece of wire I can flip and help better things .
Time to have some sleepless nights and wonder and worry...
Nah, am good .. the Tibetan sound bowls, I recently installed promote tranquility ;)
