All over the net Hi-Rez is being called useless because the focus has been on dynamic range. "You'll never use it" goes the mantra.
So I have been trying to find out if discreet voltage values or rather what and how many voltage steps there are with 16bit and 24bit within say a max output of a paltry
95dB, very usable range.
Are the jumps in assigned values (voltage step sizes) the same or not? Is 24 bit simply a longer tape measure than a 16 bit with the same metrics or at the max length of 16 bit, does 24 have more discreet values on them?
This has been bugging me for years and I can not find a comparative table or chart anywhere.
