Actually, Mike, decoupling is the same as isolation. Both refer to the act of severing a mechanical conduit so that unwanted energy cannot enter (or exit). The only problem with isolation attempts is that the mfg’er (and end-user) both are convinced floor-borne vibrations are the only significant source of vibrations that affect our sensitive instruments. Whereas I care nothing about floor-borne vibrations, since their natural behavior is to head in that direction anyway. High-end audio is not alone in these “isolation” beliefs as perhaps every other industry also follows suit.
But the real problem is not floor-borne vibrations, it’s the same air-borne vibrations you hear and feel sitting in your listening chair. Your sensitive instruments are also hearing and feeling much the same. Plus there are the constant internally-generated vibrations induced by internal power supplies, motors, etc. Like lightning rods your sensitive components are attracting this unwanted energy big time and I would attest these sources of vibrations are far more harmful than floor-borne vibrations. In which case any attempt to isolate simply traps these other sources of vibrations within the component with no hope for escape.
We’re essentially talking apples and oranges. Just like the lightning rod example. There's nothing in the world that allows me to isolate that bolt of lightning and if I did try, catastrophic harm is sure to follow. But with a lightning rod and superior grounding wire and grounding spike, that lightning bolt can be redirected before inducing its catastrophic harm. The same applies with mechanical energy, especially since electricity is simply a variation of vibration (as is all energy and all matter). You could possess the best performing lightning rod in the world, but without a superior grounding wire, that lightning rod simply cannot perform as intended. I attest that is exactly why every last playback systems performs as though it has a severe performance-limiting governor attached. Yes, that includes even the industries very best SOTA-level PB systems because energy and distortions do not discriminate.
I’ve never experimented with an active device but I’ve looked at their website a few weeks ago when somebody mentioned their product and was less than impressed. Though I suspect it may provide a bit more benefit than the more traditional isolation methods, sandbox, Sorbathane, etc. But I don’t think that’s really saying much.
Since we’re dealing with basic universal laws of nature (the natural behaviors of resonant energy), and provided one stays within the confines of those basics (not try to outsmart it) there should never be a situation where a method or execution is better in some cases but not other cases. For example, I’ve said on my website and elsewhere, “the results are massive, they are many, they are across the spectrum, and there are no negatives whatsoever. As should be the case when dealing with basic laws of nature.”
The joys of analog.
TT's often times employ layer upon layer upon layer of isolation techniques and executions. Often times, a TT's baseplate is free floating on springs or air bladders within the chassis or structure to some extent. Thus making the baseplate extremely sensitive or easily excitable (like a feather) by air-borne (not floor-borne) vibrations and thus inducing the feedback you mention. A few years ago I visited a friend with a custom rebuilt older TT (like an older Thorens) who was experiencing a perhaps not-too-dissimilar issue. His woofers were experiencing a fairly severe warble with his TT but not with his CDP. Upon evaluating his TT design, I gently placed a few pieces of material between the free-floating baseplate and the outer chassis just to firm up the baseplate making it less susceptible to air-borne vibrations. That cut the driver warble in half. Firming it up even more eliminated the warble entirely and his analog sounded significantly more musical than before. Since I don't play with TT's, that was just a shot in the dark.
In my friend's case he had some small tower single-driver units that some rate quite highly. That driver was I think 8-inches max, plus he plays music in the say 75 - 85 db range. With your bass towers I can only imagine what your TT must be experiencing.
Actually, we’re dealing with diametrically opposed methodologies and understandings. (not saying you personally but me against the entire industry and other industries.)
