Y I have become particularly suspicious of "air" -- a quality that some audiophiles crave, but which I rarely hear in live music.
Yes, a tonal balance tilted towards the lower treble will give you a superficial impression of more "resolution" and "detail", but mostly it's just an artifact that quickly becomes fatiguing. I have become particularly suspicious of "air" -- a quality that some audiophiles crave, but which I rarely hear in live music, at least not to a great extent (in some specific acoustic circumstances, yes).
The explanation was that Pepsi won on a short sip challenge because it was sweeter than Coke. However customers didn't appreciate the sweeter taste of 'New Coke' when drinking a whole can. I infer that excessive sweetness is fatiguing in the same way that digital artifacts are.
There is a LOT of air - maybe we have different interpretations of air (like people did with seamless).
But I like the audiophile word airiness and think I relate to it easily, unlike with "tonally grey" or "bleached"
Oh, I can easily relate to these latter terms
That's funny... you've described perfectly what I didn't like about the Schiit Yggy. I quite liked its 'fresh' sound at first, but it became grating after a while. Again, I'll say that I'm one of the few people who seem to have had this experience with the Yggy - most others love the way it sounds. Perhaps I really did hear something amiss (its measurements do show some strange things going on), or perhaps I had a dud unit...
Mani.
I know what you mean. There's lots of air in terms of a sort of spatiality, but to me "air" on a system often sounds, well, too "airy"
I think for untrained listeners fatiguing artifacts aren't specifically recognized... but that doesn't mean the sound is ok and it doesn't have some negative effects on the listener. I believe long term listening would make people more sensitive to differences in levels of fatiguing artifacts but it would be hard to control.
This airiness issue seems to be thorny, both in terms of what people are actually trying to describe and it's reality in terms of real music performance ie at a concert
Generally when I go to concerts I don't notice the air till you hear a long after echo when the music stops
As a performer on stage the airiness of the hall is of much more concern
I have often thought a fundamental problem of reproduced airiness is it is captured at a fixed point in the recording process
As we turn up the volume the airiness increases , but in my own experience this is not concurrent with real life situations where there appears to be a "ceiling" or less pronounced increase in airiness of the concert platform as the loudness of the performance increases
I am unclear if this is perceptual or an acoustic reality ?
As a teenager working with tape recorders I was always surprised how much more air of the room was on the tape than we were aware in the performance, I assume this is a fundamental difference between microphones and human hearing?
You have a point about untrained listeners but I wouldn't call it training as such, I would say that it's similar to looking for needles in haystacks - once one is found the visual perception has latched onto the pattern that revealed the needle & after that is established we use a pattern search with much greater efficacy rather than the "I'm looking for a needle" search. Do you get me? The thing is we can't describe what the pattern that we are looking for is, it's an abstract construct in the brain but real, nonetheless as it's efficacy in finding further examples demonstrates.
So in terms of fatigue - I believe it's caused by some non-linearities which may only occur a certain moments in playback when whatever internal conditions in the equipment cause the non-linearity. We can't exactly put our finger on what the non-linearity is (& measurements don't help when they are based on steady state signals which are not the right conditions for causing the non-linearity) so what we are left with is the feeling of fatigue - the auditory pattern causing fatigue is registered & easier to recognise when encountered again.
Auditory patterns, which is stored in certain parts of memory, do not last indefinitely & like memory the more often we encounter the same situation the more strengthening of the pattern occurs until we reach some long term auditory memories, like the sound of our spouses/childrens/significant other's footsteps or voice.
I'm pretty sure that this is what is happening from birth with all our senses - we are laying down in memory, the patterns encountered in the physical world that we are in contact with daily - so we embody these patterns & can compare them with subsequent patterns heard. I'm also pretty sure that this is how we learn to speak in a grammatically correct way - we hear speech patterns & copy that pattern so often that we embody the rules of grammar unconsciously.
I'd equate sweetness to warmth and fatiguing artifacts to something off in the food, just a tiny bit is enough to ruin the dish.
Interesting. I am also puzzled by Robert Harley's description in his review that there is more emphasis of the upper midrange and more 'sibilance'. If that were the case, the Berkeley would have to have the same thing (it sounds similar in tonal balance), but RH doesn't say anything about this in his review of that DAC. Perhaps my system balance compensates for that, but it seems unlikely. After all, I have heard the Berkeley do fine in a system with Spectral amps, amps that according to many are supposed to sound 'clinical' (??). Oh the mysteries of the high end...
From hanging out on forums over the years I've noticed there are quite a few who like their digital artifacts as these give apparent 'detail'. Indeed I once was one.
Mani.
