Any info on changes?
talking to Herve at the L.A. Show in June, he only said he was working on it (don't know when), it will be better, and that my 458's will be upgradable to the 468's.
not a word on what might be different. the 458's are now an almost 8 year old product, so it's certainly a reasonable idea that Herve has found another step forward.
no offense Mike, but a new 108 would be far more exciting![]()
as far as upgrading the 108.......that might require much more time and trouble than the 458 and have less rewards. it could be in the works, but i have no knowledge about it.
Hong Kong dealer just got delivered with serial number 9. I guess there are 9 pairs of 468 made already. I also believe most of them sold to China. And my 468 was delivered two weeks ago. I can only say the sound is spectacular. Best power amps I ever owned or listened.
It is no longer in gold? Now I am more interested.
.(prefer the gold/red 'ironman' myself for this amplifier design).
Pardon me for saying this uncle Mike. But your system is not exactly a mix-and-match aesthetically sir.
(Cant help not teasing you.)
Tang
Dear Tang,
that is an interesting comment. anyone looking at pictures of my system might immediately assume I love red, gold, black, and blond wood. but the only part I choose is the blond wood and my red and black wool carpet in the center of my room (and I've since wanted to change that). that is a relatively expensive piece of carpet I purchased 14 years ago before darTZeel or Evolution came to my room.
I wish darTZeel looked like the Mark Levinson gear I used to own. the Evolutions have never floated my boat as far as color (would prefer a more neutral color---but do consider them nice looking and beautifully built). I wish my hardwood floor and carpet was a much darker shade. but I don't acquire gear based on the look. and I can't justify re-doing my floor just for the color.
all that said; I've seen pictures of the black and silver 458's and for that design I easily prefer the red and gold (and I don't 'love' the red and gold). I do consider the 458's to look elegant and stunning in person and they are magnificently assembled and a joy to touch every day. there is zero compromise anywhere in or out like all darTZeel products.
I don't for a minute regret any of my purchases in these colors, but none were purchased for the look. and over the years I've had plenty of homely looking gear that happened to serve the music well.
best regards,
Mike
wow! congrats!
thank you for the feedback, obviously I am 'hungry' for listening impressions on the 468 as I am 'in line' for the upgrade from 458 -> 468.....and there have been no comments I have seen about it other than from Herve.
were you a 458 owner before? or have you compared the 2 models? any impressions of what changed?
Thanks Mike. I have owned countless amps. High power tube, high power SS, SET. Never satisfied. Your system is great inspiration to me. It makes me consider darTZeel. I am able to get a second hand NHB 108. Now I can understand what all the fuss about. Hong Kong dealer offers me a great deal on 468. I am a bit hesitant as my speaker is a horn speaker. I do not need all the power. I have communicated with you on the difference between 108 and 458. Your answer push me to purchase a 468.
And 468 turns out to be a much better amp than 108 even the max power I have seen so far is around 36W given that I listen very loud. All the amps pale in comparison to 468.
Sorry, I have not listened to 458 before and cannot answer your questions on the differences between 458 and 468. But I am sure 468 is a big improvement over 458.
As far as I can tell, the casing and colour of 458 and 468 are the same. The back panel layout is the same. I think there are some changes on the meter.
Dear Sir,
Are you using a Cessaro?
Kind regards,
Tang
I see there is a model two of the NHB-108 @150 watts. Is this new?
Thanks Mike. I have owned countless amps. High power tube, high power SS, SET. Never satisfied. ...Your answer push me to purchase a 468.
And 468 turns out to be a much better amp than 108 even the max power I have seen so far is around 36W given that I listen very loud. All the amps pale in comparison to 468...
Hi Tang,
My horn speaker is Aries Cerat Symphonia.
