Tidal or Competitor Without a Computer (like Spotify)
asiufy
Industry Expert/VIP Donor
Jul 8, 2011
3,711
723
1,200
San Diego, CA
almaaudio.com
Thank you, Alex.
I definitely do not want Roon. The information on Qobuz will be plenty for me.
Does the MSB Renderer module allow one to feed Qobuz directly to the MSB DAC without using a laptop or a music server?
Not through the Renderer. You'll need to output USB via the server of your choice.
I respect of your choice of not wanting Roon, but I don't understand it :) It does bring you back at least 2-3 years in terms of ease of use.
16,185
13,611
2,665
I’m sure you’re right, Alex, but right now Roon seems like another piece I don’t absolutely need.
What, then, does the Renderer module do?
16,185
13,611
2,665
Oy vey!
Innuos versus Aurender? :eek:
Which is the highest sound quality device which simply accepts the Qobuz digital source for streaming, allows itself to be controlled by an iPad, and does not have an on-board hard drive or anything else the MSB DAC does not need?
asiufy
Jul 8, 2011
3,711
723
1,200
San Diego, CA
almaaudio.com
It accepts data (music) over the network directly, using a number of different formats. Roon is one of them. UPNP/OpenHome is another one.
The Qobuz app won't output any of those formats over the network, on its own.
Since Tidal and Qobuz are integral parts of Roon, they come "free" with it. So Roon can send music to the Renderer, be it files or Tidal/Qobuz streams.
With Roon, if you pick a track or album as a favorite, it'll also show up in the Qobuz app, and vice-versa.
asiufy
Jul 8, 2011
3,711
723
1,200
San Diego, CA
almaaudio.com
Oy vey!
Both units will do what you want. But my choice right now are with the Innuos products.
They both have hard drives, though. Can't escape those.
Innuos comes with a built-in music player, that, frankly, I haven't used much. But it does say it's *gasp* Spotify compatible (Tidal and Roon as well).
http://www.innuos.com/en/catalog/go/music-servers-mk3
Mike Lavigne
Apr 25, 2010
12,587
11,663
4,410
Oy vey!
likely the Taiko Audio SGM Extreme is the best sounding.
while it has control memory modules they are discrete. it's capable of having storage but that's not required. you might keep your mind open to having files as well as streaming. once you dip your toes into the raging river of digital it might pull you in.
the Extreme is likely orders of magnitude more robust than those other choices, and priced appropriately.
https://www.whatsbestforum.com/threads/taiko-audio-sgm-extreme-the-crème-de-la-crème.27433/
Reactions: Ron Resnick
Folsom
6,029
1,501
550
Eastern WA
I would vote it's the opposite of what you say. It appears highly fragile, unable to be stable signal wise. It's distinctly for curtailing the sound in some way as far as I can tell. I'm not saying that's wrong, it might be exactly what someone is looking for in sound. But, as I sorta said already, I think introducing these extra variables creates a tail chasing scenario.
On the other hand the Innuos looks legit.
16,185
13,611
2,665
So the Renderer module lets you avoid a server, but you need Roon to carry the Qobuz signal to the MSB DAC? So if I play Qobuz through Roon then I do not need a server?
Number9
Active Member
Oct 15, 2018
131
43
35
The Zenith is hard to beat imo. It is very easy to use and the customer service is excellent if ever needed. I have never heard the Aurender but I am always reading about various software related issues. There is a small learning curve Ron but after a few hours you’ll be fine. You might even have a little fun with it.
asiufy
Jul 8, 2011
3,711
723
1,200
San Diego, CA
almaaudio.com
You do need a server to run Roon. The only way to avoid a server altogether would be to send data directly off your phone/tablet to the Renderer module, and that isn't possible yet. Perhaps if one day MSB updates it to support either ChromeCast or AirPlay, but I don't believe that's in the cards, as those are lossy transport protocols, so it sorts of defeats the purpose of having an MSB DAC in the first place.
I concur with Number9, the Innuos Zenith is a great choice, at a good price/performance ratio.
16,185
13,611
2,665
Gentlemen, I am getting confused. So the Innuos Zenith has a built-in DAC which outputs an analog signal? So I would not need the MSB DAC? :rolleyes:
Or is the Zenith just a streamer which outputs a digital signal?
Does the streamer affect the final sound quality just as much as the DAC? :oops:
asiufy
Jul 8, 2011
3,711
723
1,200
San Diego, CA
almaaudio.com
2nd option :)
Any music server is like to a disc transport, it'll feed the bits to the DAC. EIther via USB, or preferably, via network (Renderer module).
And no, (fortunately) the server does not affect the overall result as much as the DAC does. But in a revealing high-end system, server differences will be pronounced and noticeable.
I've found out that with servers, the gains are generally in better sense of relaxation, greater lack of grain/harshness, and better overall clarity/transparency. As you can imagine, the better servers will give you a relaxed presentation, with no grain/harshness, and plenty of transparency :)
NorthStar
24,305
1,323
435
Vancouver Island, B.C. Canada
? https://www.planetofsoundonline.com/pages/how-to-get-great-sound-from-your-iphone
Reactions: Ed.P
16,185
13,611
2,665
Thank you, Alex, for this tutorial!
Folsom
6,029
1,501
550
Eastern WA
2nd option :)
Low noise from the server is good. However MSB and many other DAC's are fairly immune. Generally speaking the server has to induce jitter or other distortions to cause any difference in quality of sound. That's what most of the products do, because no one is hardly ever happy with straight forward digital. Most straight forward digital setups are too accurate, or they miss really important things that affect SQ that people just don't know about.
16,185
13,611
2,665
SO which sounds more like analog? Zenith SE Mk II or the new ZEN Mk3?
16,185
13,611
2,665
Before we (ah, I) get carried away here I think I will have to return to KeithR’s system and do a careful and leisurely direct comparison of London Grammar’s “Strong” and Sarah McLachlan’s “Witness” (both digital recordings) on LP versus Tidal stream.
But I do think having a digital streaming capability for convenience for me and for flexibility for visitors makes sense.
Qobuz + Innuos + wi-fi + MSB + iPad = o_O
Reactions: Folsom
16,185
13,611
2,665
Ah, I see the MSB Pro USB interface let’s me avoid having to locate an ethernet connection near the source components rack?
Taiko Audio
4,297
13,340
1,925
The Netherlands
taikoaudio.com
Hi Ron,
Yes, if you would be asking me I would recommend going with the MSB Pro USB interface. You can run any length of really thin fibre cable from your DAC to any server device with zero cable emissions. Could even be your home office computer. I would recommend you start there and if you like what it is doing for you you can always consider upgrading to a purposely build audiophile server.
asiufy
Jul 8, 2011
3,711
723
1,200
San Diego, CA
almaaudio.com
That's true.
The only reason I don't emphatically recommend the Pro USB module is because I haven't heard it yet, and I'm not into the habit of recommending stuff I haven't heard :) But as I said before, it does look fantastic, and should be a viable alternative for network-based streaming.
