Tidal or Competitor Without a Computer (like Spotify)
4,700
Bill - no. But I have tried a few different interface methods and USB devices etc. Ked brought a USB one round that I thought was pretty dire.
Anyway it's just a cheap solution anyone can try.
Ked. Bring one round. I bet you £1k you cannot reliably tell me the difference at better than 7 out of 10 tracks blindfolded.
Make that £2K.
Up for it?
I am.
Listening tests need proper positive validation and controls. First tell us of something of similar type where you have reliably found a difference of better than 7 out of 10 tracks blindfolded.
asiufy
Industry Expert/VIP Donor
Jul 8, 2011
3,711
723
1,200
San Diego, CA
almaaudio.com
Thank you very much for your detailed reply.
We don’t want noisy, digital-carrying ethernet wire near phono stages, correct? So is that why we keep the server far away and we use the MSB Pro USB to take the digital signal out of the streamer’s USB port at the server end, and send the digital signal to the MSB Pro ISL at the MSB DAC end, and then we connect the Pro ISL to the MSB DAC?
This lets us use fiber optic cable from the Pro USB all the way to the DAC. Do I understand this correctly?
Or is the Pro ISL used only if one is using a physical media transport?
Ron,
Upon assessing your particular situation, I believe the best interface for you, for an MSB DAC would be indeed ProISL + ProUSB module. That will allow you to stream directly from any USB-based device (Innuos, cheap Mac, your phone), and if MSB's claims are real, the actual server/device being used will have less impact than through regular USB due to the noise suppression performed by the combo ProISL+ProUSB.
Again, I haven't really heard that combo, and I don't like commenting on things I haven't heard, but I know what the ProISL can do with spinning discs, so if it's even remotely close to how their transport sounds (via ProISL), we're all in for a real treat :)
cheers,
Alex
Reactions: Taiko Audio
KeithR
5,156
2,821
1,898
Encino, CA
since when is ethernet a noise problem and particularly isolated ethernet as Innuos does?
Reactions: Folsom
Zero000
2,985
1,140
478
Never done one. Ever. Gotta be pretty desperate to bother and probably way too serious. Not denying it would be interesting.
Micro I was playing with Ked. We do that with each other.
16,188
13,615
2,665
Ron,
cheers,
Alex
Thank you Alex (and Emile). That sounds like the right thing for me eventually: I can keep the Innuos streamer away from the audio source rack, use the Pro USB at the streamer end and the Pro ISL at the DAC end.
Does the Innuos streamer have to be connected to my wi-fi via an ethernet cable?
Is connecting the streamer to the wi-fi router how the streamer gets the Qobuz digital signal and is able to be controlled by an iPad operating on wi-fi?
Taiko Audio
4,299
13,354
1,925
The Netherlands
taikoaudio.com
I don't know if Innuos has wifi by default or as an option, I'm sure Alex does, but if not you could probably hook it up to an apple airport express for wi-fi support.
The streamer just needs an internet connection, wired ethernet or wi-fi, does not matter functionally.
thedudeabides
2,170
676
1,200
Alto, NM
You’ve just opened another momumental can of worms/maze to navigate!
My experience exactly. I bought an Auralic Aries and an iPad, subscribed to Tidal and disconnected / sold / returned all the following day. Took a computer consultant 1.5 hours to navigate all the techno crap to install and when it finally was up and running, the software sucked. A huge disappointment. My first and last foray into the hidef streaming world. Sticking with my Magnum Dynalab XM tuner.
Reactions: NorthStar
thedudeabides
2,170
676
1,200
Alto, NM
The Zenith is hard to beat imo. It is very easy to use and the customer service is excellent if ever needed.
With all due respect, when I read stuff like this, all I can do is laugh.
still-one
1,633
150
1,220
Milford, Michigan
Ron
Pick up something like the under $800 Small Green Computer i5. Attach that to your network anywhere in your home. That is where Roon Core will reside and allow access to either Tidal or Qobuz. You then attach your MSB device via ethernet to your network and voila you have outstanding SQ all at your fingertips, You will also need a iPad or laptop (both wireless) connected to your network. Don't fiddle with USB or other connections, ethernet is the way to go.
Note: If you want to have them add a SSD drive (as I did) to the i5, you can place your own music files on the network there if you ever desire.
PS: I see they are one of your advertisers.
I can'r figure why anyone would want to dangle a laptop or similar device off their audio system. That's like hanging fuzzy dice on a Ferrari's mirror. Hide that stuff in a closet.
marty
4,198
2,520
United States
Isn’t seven out of 10 statistically significant?
This is actually a meaningful question and without delving into statistical gobblygook, the short answer is:
Discerning a difference 70% of the time might be statistically meaningful to some but in general it’s a low hurdle. In the science world, if you don’t show that something is significant with a probability that your results will be better than chance 90% of the time (depending on the design of the study and type of analysis performed) you probably won’t be able to get it published anywhere except the “Journal of Irreproducible Results”. (Believe me, I’ve tried.) Most credible journals require outcome probability better than chance alone of 95% (p< 0.05) which is really the gold standard.
So, 7 out of 10, not particularly impressive; 8 out of 10, a bit better; 9 out of 10, now yer talkin’; 9.5 out of 10; homerun!
Folsom
6,029
1,501
550
Eastern WA
Well and maybe get it added to the Food Pyramid/healthy food lists.
asiufy
Jul 8, 2011
3,711
723
1,200
San Diego, CA
almaaudio.com
Yes, the Innuos needs to be connected to your house network, via Ethernet cable. It doesn't have Wi-Fi capability on its own, but we've had good success using Wi-Fi extenders.
And you nailed it, once the Innuos is on your network, it'll be able to pull Qobuz data, as well as be controlled from any device sitting on your network, iPad, phone, computer, etc.
Reactions: Ron Resnick
asiufy
Jul 8, 2011
3,711
723
1,200
San Diego, CA
almaaudio.com
Have you had one? I saw your post on the Auralic, and I can completely understand your frustration. All the Innuos products are SUBSTANTIALLY better than Auralic's, in every single aspect.
16,188
13,615
2,665
Ron
Thank you, but I don’t want to add a computer device. I don’t need Roon..
I intend to plug a streamer into an ethernet jack
Mike Lavigne
Apr 25, 2010
12,587
11,663
4,410
any 'streamer' is also a computer device. the degree of capability might vary. the music selection software for the streaming service has to reside somewhere. and this computing device can be your phone.
the only exception would be if your dac also has the computing device built in designed to handle the streaming service (like a smart phone does). likely not ideal for performance. and MSB dacs do not work this way. typically you would use your phone or a tablet as a remote (over wifi) to select specific music.
spiritofmusic
14,625
5,432
1,278
E. England
Dallyboy, U1 Mini is in pole position for my streaming option, going into a Kitsune Level 3 Holo Springs dac.
My local dealer loves this combination.
If you're familiar w it, which would you favour re connection to dac - USB, AES/EBU or I2S?
Dallyboy
6
63
Hi Spiritofmusic,
I found that I do prefer the AES/EBU and the I2S over USB. Both provided a dense staurated sound with better dynamics and sound staging then USB. Tough call on which was better though. I do favour the AES a bit more then the I2S but really it will be your system an ears that will tell you which way to go.
