Low compliance MC cartridge
Exlibris
588
429
198
Canada
systems.audiogon.com
I'm looking for recommendations on a low compliance MC cartridge.
Specifications
Mass: <10 grams
Compliance: low
Output: >0.29 mV
Output impedance <11 Ohms
Loading: ~200 ohms
Budget:
<$5,000 USD (new, retail)
Candidates (in no particular order):
1. van den Hul Crimson XGW Stradivarius (low compliance version?).
2. Koetsu Rosewood (and many others)
3. My Sonic Lab Eminent Ex (GL)
4. ?
Exlibris
588
429
198
Canada
Candidates
1. van den Hul:
2. Koetsu:
Black Goldline
3. My Sonic Lab:
Eminent Ex (GL)
4. Hana:
ML
5. Air Tight:
PC-7
6. Ikeda:
9TS
Note: some of the candidates may be slightly off on one or two of the criteria listed in the OP.
bonzo75
22,650
13,685
2,710
London
These are so different. Only you can judge. Since you are less classical, and more rock, if I recall correctly, you should drop vdh off that list. It is my favorite cart along with red sparrow on a linear tracker, but not for rock.
Reactions: gian60
Exlibris
588
429
198
Canada
You remember correctly: more rock than classical.
Thank you for the suggestion.
The only cartridge on the list that I've actually heard is the Hana but it was in a system I was hearing for the first time and we didn't do any cartridge swapping.
Exlibris
588
429
198
Canada
In Herb Reichart's review of the Hana ML and Etsuro Urushi Cobalt Blue he makes mention of these cartridges' sense of space. The system with the Hana certainly had a wonderful way of projecting music out beyond the speaker plane. When things got complicated, however, the sound recessed back to the speaker plane.
bonzo75
22,650
13,685
2,710
London
Hana is a good value for money cart but not on same league as better carts. For rock you should look to get a Garrard or a direct drive like Sony 8000. Then add a SPU on FR 64s and rock out. This is Garrard with a SPU on under 5 watts
Reactions: gian60
Exlibris
588
429
198
Canada
I do have an idler wheel table and I like the sense of space and unrestricted freedom that my linear tracker provides. I don't only listen to rock, I like a lot of softer, acoustic fare as well.
Exlibris
588
429
198
Canada
I do have an idler wheel table and I like the sense of space that my linear tracker provides. I don't only listen to rock, I like a lot of softer, acoustic fare as well.
I take your point on the Hana though. The two guys in the room with me at the time both have experience with it and would agree with your assessment.
bonzo75
22,650
13,685
2,710
London
Ok, vdh will be very good on acoustic
Reactions: gian60
Exlibris
588
429
198
Canada
I spoke with the manufacturer of my tonearm (Leif from Air Tangent) and the manufacturer of my phonostage with built-in SUT (Thomas Mayer). They each told me what their particular component likes/needs from a cartridge.
bazelio
2,494
1,748
345
California
Why is that? Is the Crimson that much different than the Master Sig? In the case of Master Sig, it sounded great on Led Zep III over at @mountainjoe 's place. It swings.
bonzo75
22,650
13,685
2,710
London
Led zep III is largely acoustic which suits vdh. Otherwise I think for rock it is a bit leaner, and can highlight the grunge more than required
defride
309
200
1,185
Have you done direct comparisons. What have you compared the ML too?
Exlibris
588
429
198
Canada
Etsuro Urushi removed from list of candidates because of high compliance.
Candidates
1. van den Hul:
2. Koetsu:
Rosewood
3. My Sonic Lab:
Eminent Ex (GL)
4. Hana:
ML
bazelio
2,494
1,748
345
California
OK, I can see most of that. Just not the leaner part. At least not with the black wood master sig. Reproduction of bass drums is probably one of the biggest faults with the vinyl format (IMO) overall, and I feel the Master Sig does it as well as any cart I've ever heard. Highlighting grunge a bit I can see. Some might like that though.
defride
309
200
1,185
I have not. The only cartridge on the list that I've actually heard is the Hana but it was in a system I was hearing for the first time and we didn't do any cartridge swapping.
Have you?
I have an ML so interested in comparisons as I've only heard it back to back in my system (SP10mk2, Funk FX3, Groove SRX) vs AT PTGii and a Denon 103. Very happy with it
Wondered if Ked has had the opportunity
Will be interested to hear how you get on as all the carts you mention are of interest when the time comes. Someone on here recently purchased an Etsuro Cobolt, that's another in this ballpark that may be worth investigating?
Exlibris
588
429
198
Canada
Unfortunately I just dropped the Etsuro from my list after reading that is in fact a high compliance cartridge. I'm looking for low compliance but low-medium (and even medium) would be okay -- but not high.
Kcin
663
849
275
Canada
I have heard the Hana
My reference at home , Goldfinger Statement , Koetsu Jade, Atlas, Etna SL I also have an almost zero hour RSP Koetsu. I've been using a 4pt and a FR64s ( mainly for the Koetsus- but it it extraordinarily accommodating of most cartridges)
Heard Hana at my dealer friend as well against GFS, Miyajima Madake, DV XV1s and more.
The Hana is an excellent performer and value but not in the league of those listed for what they do well. You have to choose your priorities.
Reactions: Exlibris
