Pacific dac: Lampizator's new top of the line dac
wisnon
3,536
640
1,200
Hey Norman, funny you say that - the magical SE B7 that I home trialled way back, also had a volume control, but my current B7 doesn't - though on the loaner unit, I always set volume to max, and controlled it via my preamp.
So the lack of 'magic' with my current unit could be the balanced vs SE issue, or the lack of a volume control (or both).
I would guess both. If you do upgrade and get one with a VC, PM me and I will walk you thru how to tune it to how you like it with VC and other tricks.
wisnon
3,536
640
1,200
Hey Christoph,
Back with the p2p wired B7 it had Psvane 101D's and some EML 45 mesh tubes I think. The EML's sounded dreadful at the time (flat and lifeless), but the 101D's sounded amazing. Can't remember the recti - whatever was stock back then (5U4G perhaps?). All I remember was the palpable three dimensionality of the thing, it was awesome - the best my system has ever sounded.
With my current unit I have the 101D's, 242's, Psvane UK 300B, KR-300B RK versions and KR 45's, and a bunch of recti's including the Tak 274B, KR 5U4G Anni, Chatham 5R4WGA, EML Mesh 5U4G, a cheap Shuguang 274B, and a big ugly USAF 596 thing with wires coming out of it that I've not really used much.
the 596 is da bomb. 3 of us just got it and are in heaven. Now Chris wants one even though its fuggly.
Reactions: christoph
bonzo75
22,650
13,685
2,710
London
"ancillary streaming hardware" for me is SoTM SMS200Ultra > SoTM txUSBUltra plus external clock, plus power supplies for all three. I've had enough of all the boxes, I just want to go ethernet directly in to the DAC.
Incidentally I don't have a GG1, but a B7.
I loaned a SE B7 years ago, one of the original versions with the point-to-point wiring, and it was magical in the three dimensional image it created in my system. Three years later, and the balanced B7 I have now (a more updated version with the printed circuit board), whilst nice, delivers nowhere near the magic of that first unit. I'm kind of hoping that if I eventually move to a GG2, I can recapture some of that magic. Who knows, maybe it was just exclusive to that point-to-point wired version. It is a bit annoying that Lukasz doesn't keep a consistent design within the same model.
It is not exclusive to P2P version. The updates since then have mostly been useful and going from delight to delight but I have long since recommended staying SE as that is what I believe. I am sure I must have told you that as well if you look at past posts but I can understand why you chose otherwise.
Do you have all those tubes you mentioned in quads?
Wookii
50
13
8
I’m not that impressed with it. It’s not an offensive recti (other than to look at!) in any one sound quality direction, but the Tak, the Chatham (that you put me onto) and the KR 5U4G Anniversary are far superior in my humble testing, with the main tubes I have.
Wookii
50
13
8
Yes, I’m sure you probably did Ked, but the rest of my system is balanced right through, so a non-balanced DAC was a mind-block for me.
Yes, I have all the tubes in matched quads, so I’ll need to off-load half of them if I do eventually go SE.
bonzo75
22,650
13,685
2,710
London
I think both Tak recti and Tak 300b artificially enhance the mids making them thick and pushing them forward so I don't like them
bonzo75
22,650
13,685
2,710
London
ok it's good you got them in quads and went all out
Golum
1,814
2,577
405
Lausanne, CH
Golum
1,814
2,577
405
Lausanne, CH
.... but the rest of my system is balanced right through, so a non-balanced DAC was a mind-block for me.
Same was my initial thinking, but once you overcome it, you are sailing on the clouds...;)
Wookii
50
13
8
I’ve not found that to be fair. The Tak 274b does seem to be more etched and produce more resolution - I wouldn’t call it thick sounding, if anything it’s on the leaner side to me. One of the main things I’ve found in this voyage of discovery is the recti needs to be matched to the main tubes, I haven’t found a recti that works well with all output tubes, and visa versa.
The Tak sounds superb with the 242’s for example, but sounds terrible with the 300B’s, where the Chatham or 5U4G sounds much better.
bonzo75
22,650
13,685
2,710
London
Interesting, might be matching then
christoph
4,689
4,077
825
Principality of Liechtenstein
Hey Christoph,
Wow, you have a nice stash of interesting tubes :cool:
What pairing sounds best to you atm?
Wookii
50
13
8
The 242’s sound really good with the Tak, though I think they are probably driving the pre-amp input a little hard, so they can sound a little forced on some tracks. They do everything well that we traditionally search for in ‘hifi’, great soundstage, superb detail and resolution etc.
But my favourites so far are the Psvane UK 300B with the Zaerix 5R4GY recti (one I forgot to mentioned in my previous post), or the Chatham recti. It’s hard to actually put my finger on what I like about them. They don’t stand out as excelling in any of the traditional ‘hifi’ areas that many of us might look for; detail, resolution, three dimensionality, soundstage etc, there is just something intangible about what they do - the music just washes over me and draws me in more than any of the others, something just engages with me on a different level somehow - it’s hard to explain.
Most of the time when I’m trying these tube and recti combos, I’m constantly flicking between numerous reference tracks, listening for differences. But with those I just couldn’t skip on to the next track, before I knew it I’d listened to music for two hours without barely skipping a track, and without getting up to swap tubes again, which is what I was supposed to be doing. I guess that’s the best possible sign, when you find yourself actually listening to the music rather than analysing the sound, almost against your own intentions!
That’s very much what that initial p2p wired B7 did that I referred to earlier - but that did it whilst also producing a massive, palpable, three dimensional soundstage at the same time, that these 300B’s don’t particularly do.
The biggest disappointment so far have been the Kron RK 300B’s, especially given their cost. Though to be fair they probably haven’t been burnt in long enough yet (<20 hours).
christoph
4,689
4,077
825
Hey Christoph,
Where are you located, Wookii?
Any possibility you could try the RK PX25 from someone close to you?
That one could possibly match your taste
christoph
4,689
4,077
825
Thanks for your experience :)
This is very interesting for me, because ears I trust tell me that the fugly Frankenstein (aka 596) is extremely good :eek:
The Chatham is the Potato Masher, right? IME very good, but not in the league of the RK KR 5u4g :)
christoph
4,689
4,077
825
Golum was in the same situation and ask him now ;):cool:
Off-loading so many precious tubes could maybe free some funds for an SE Pacific when you can trade in your B7 as well ;)
christoph
4,689
4,077
825
Is this only valid for all-in orchestra or also other Music Genres?
Do you feel the Taka Combo is limitied on the frequency extremes when you say the mids are pronounced?
bonzo75
22,650
13,685
2,710
London
I won't say limited, but the mids were fattened up and stage pushed forward. I sensed that in Al's system (Big 7) with the recti and in two Alieno systems with the 300b in the power amp. The KR and Westinghouse recti were more linear and the Elrog and KR 300b were more linear as well, with the Elrog being the best of those. The RK recti is currently my favorite
Reactions: Golum and christoph
