This is a great comparison Tim. I realize this is really old, but I’m trying to decide between a Triplanar U12 and Kuzma 14 4 Pt so this is helpful. Thanks!Since 2013 I've had a Tri-Planar Mk VII U2-SE ordered with copper wiring - this is the 10-inch version. Back then I also had an SME V which after a while I sold. At present I also have the Kuzma 4Point 11-inch.
In some areas, the 4Point draws from the Tri-Planar design heritage: VTA tower w/ VTA on the fly; removable horizontal damping fluid trough; similar azimuth adjustment. Both 'arms are easy to set up and easy to use.
The Tri-Planar holds its settings very well over time. Azimuth has slightly finer adjustment than 4Point. 4Point has finer VTA adjustment than Tri-Planar. Tri-Planar allows adjustment of cueing speed, 4Point does not. On Tri-Planar you must have arm lock open before raising cueing lever or eventually cueing mechanism will leak.
Effective mass of Tri-Planar is 11g; 4Point is 18g. Lower compliance cartridges work well with the 4Point. As usual pay attention to cartridge matching. As @Audiophile Bill and I learned, some vdH carts out of box will not fit Tri-Planar - see here.
Sonically, 4Point is a bit more transparent and resolute, most notably in the lower mid-range and mid-bass to low bass region. Both arms do well on music with a vivacious fluid character, themselves bringing no grain or etch. Upper-highs may be a teeny bit smoother on Tri-Planar ... may be. If I look at my own usage between the two, I use the 4Point ~ two=thirds of the time.
Is your 2/3 usage of the Kuzma primarily because of arm or cartridge preference?You are quite welcome. My post is a few years back but the arms are essentially the same although the 4Point now has upgraded bearings.
Two other items: The Tri-Planar has a flat base with its cable coming off the side of the VTA tower, while the 4-Point requires a hole for mounting with its lower section below deck level, with its cable coming out the bottom of the arm.
Both arms can be ordered with different wiring. The default for the Tri-Planar is silver but can be ordered with copper. The default for the 4-Point is Crystal Cable silver-gold tonearm wire; options include Cardas Clear (copper,) Konda (silver,) and Crystal-Cable MonoCrystal. I have the Kondo but caution it is expensive. If I had it to do over again I might opt for the Cardas.
A recent conversation with another Triplanar user suggested that its arm's advantage can be attributed to the bearings. This discussion seems to indicate that the most recent 4P improvements are, in some respect, due to improvements to the bearings. Can you elaborate?I like both arms. The 4P has the removable headshell which makes cartridge change easier. The 4P has a slight edge over the Tri-Planar in mid to low bass articulation and tone.
